Old 04-21-2011, 09:30 PM   #1
flatblkserria82
pinion angles
The truck 82 half ton dropped 6 in the front and 6 in the back
I'm having u-joint problems obviously' but what i was wondering what angles do the pinions have to be, or what shims to order, is what i need to find out. The truck has a two piece drive line so the carrier bearing and the rear needs shimmed, i heard that 2 degrees within the carrier and trans is what i was told just wondering what everyone els did with the shims.
flatblkserria82 is offline   Reply With Quote
Old 04-22-2011, 05:29 PM   #2
cpetersen
cpetersen's Avatar
Re: pinion angles
I had the same problem, mine is a coil set up. The rearend shop said i should go 6 degrees. Good luck
cpetersen is offline   Reply With Quote
Old 04-23-2011, 01:35 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: pinion angles
hope this helps if the trans is down 3 degrees the rearend needs to be up 3 degrees.
KQQL IT is offline   Reply With Quote
