![]() Join Date: Apr 2011
1967 Chevy C10
I just picked up the above truck and am trying to figure out what motor is in it! The only data is on the front passenger side of the block - F04I4D - no vin was in this location, is there another place it might be?
Thx Mike |
Re: 1967 Chevy C10
PRETTY sure that 230-250's have a 4" valve cover and 292's have a 6" cover. I THINK that the fuel pump is behind the motor mounts. Do a search for I6 engine id and youll find TONS of info.
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." |
Re: 1967 Chevy C10
Thx,
But this is a V-8 motor, not an inline 6. |
![]() Join Date: Mar 2010
Re: 1967 Chevy C10
The back of the block. Just below the dizzy.
Re: 1967 Chevy C10
If original motor check the spid or run the vin through the site vin decoder.
Re: 1967 Chevy C10
Thanks will check it out today. The truck was originally a 6.
Active Member
![]() Join Date: Jul 2007
Re: 1967 Chevy C10
Re: 1967 Chevy C10
Found the casting number, 3849852 so I know it is a 64-68 283 from a Chevelle!
Some site say "SJ 2B" next to the casting number, I assume 2B is a 2 barrel, but no idea what the SJ stands for. Still don't know how to translate the F04I4D, I assume F = Flint, 04 = 4th day, I = Sep, 4= 1964, D = ?? |
Re: 1967 Chevy C10
I found it to be a 1957-66 283 with 220 hp., two bolt main, out of a car or truck.
Active Member
Re: 1967 Chevy C10
Those were great little engines. Very durable and ran great on the old 56 with a 4 barrel I used to have. Almost indestructable.
Re: 1967 Chevy C10
Newtz67,
How did you decode the engine? This where I found mine: http://www.tracyvette.com/blockssb.html Thx, Mike |
#12 | |
Re: 1967 Chevy C10
#13 |
Re: 1967 Chevy C10
Thanks for the info.
#14 |
Re: 1967 Chevy C10
