Old 04-22-2011, 01:20 AM   #1
66 lwb cs
66 lwb cs's Avatar
Front clip from late model
I was wondering how late a model of truck you can swap in the front clip from onto a 66 C20? I saw another thread talking about using a 73 clip to get the discsand the 5 lug setup as well as the control arms for using C10 lowering gear, and how it was a bolt in affair so was wondering how late a generation clip you can just bolt under one of the older trucks 80's 90's 2000's are they all basiclally the same set up? Also any hints on the rear axle swap would be appreciated as well did a search but didn't find this question answered. Thanks in advance.
66 lwb cs is offline   Reply With Quote
Old 04-22-2011, 01:28 AM   #2
Captainfab
60-66 Nut
Re: Front clip from late model
Here is a good thread on the front disc brake conversion.
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
There is a good list of informative threads in the FAQ at the top of this section. Basically everything that works for the C10's will work on a C20. You can use a front suspensionm steering and brakes from a '71-'87 C20 or single wheel C30.
The only direct bolt in rear end that would be better than the HO52 you likely have would be a Dana 60 from a '67-'72 C20, but those aren't easy to find. Any other 8 lug rear end is going to require cutting, welding and some fabrication to convert. If that is something you are able to do, then I would look for either a 14 bolt from a '73-'87 C20 or single wheel C30, or a Dana 60 from a F250. The full floating version of either would be the better choice. If you decide to go with a 14 bolt, I have some trailing arm brackets for that conversion. I can also help you with the power steering and power brake conversion.
Old 04-22-2011, 01:32 AM   #3
66 lwb cs
66 lwb cs's Avatar
Thanks for the info but I was trying to find out about converting the axle to the 5 lug C10 style set up maybe my post was not clear but thanks and will check the FAQ
66 C20 LWB CS 327/TH400 A/C
Old 04-22-2011, 01:36 AM   #4
Captainfab
60-66 Nut
The same would apply that I mentioned above, you would just need parts from a C10 instead of a C20.....it all interchanges. The one exception to that is the lower control arm shafts on your '66 C20 are different than later model C10's. So to convert to a C10, you will have to either switch the entire crossmember, or do some fabricating to mount up the C10 lower control arms.
Old 04-22-2011, 01:42 AM   #5
66 lwb cs
66 lwb cs's Avatar
Right I was wondering because I saw another post on here where a guy picked up the whole front clip from a 73 for 100.00 off Craigs or something and how it bolts right up to the crossmember of a C20 thus turning it into a c10 only requiring plumbing for the disc brakes and making the whole conversion alot easier. He had a pic of the front clip he picked up and I was wondering how late a model has the same style mounting crossmember to bolt right up so I can cruise Craigs looking for a C10 being parted. Thanks again.
Old 04-22-2011, 02:16 AM   #6
Captainfab
60-66 Nut
This was covered in my posts above.....
Old 04-22-2011, 11:03 AM   #7
66 lwb cs
66 lwb cs's Avatar
Thanks again for the info will do more reading.
Old 04-22-2011, 02:45 PM   #8
kieth
kieth's Avatar
u can also use up to a 91 suburban
kieth is offline   Reply With Quote
