04-22-2011, 04:13 AM | #1 |
What to use for lubricant?
Putting the 327 and SM465/NP205 setup together for the 68 4X4 burb.
What is the correct lubricant to use on the clutch splines and throw out bearing?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 04-22-2011 at 04:22 AM. |
04-22-2011, 07:00 AM | #2 |
Redefining LowBudget
Re: What to use for lubricant?
nothing!! I never put anything on them since the dust would collect on them and might make them stick.....kinda like brake adjusters....I do put a dab of grease in the pilot bushing/bearing but it more of a help assemble thing
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-22-2011, 09:45 AM | #3 |
Just a car guy
Don't want that lube slinging out and getting on flywheel or clutch friction surfaces either.
If anything, maybe a dab of anti seize? Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
04-22-2011, 11:40 AM | #4 |
Grandpa in the rustmobile...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-22-2011, 12:11 PM | #5 |
I would replace the throwout bearing at the least before putting it back together. The clutch fingers look like they have some wear on them, and I believe the original type clutch would have been a diaphragm, so if you don't know how good the clutch is you might want to replace the works and get the flywheel surfaced. I know, one thing leads to another on these, but it is a lot easier to do it once.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
04-22-2011, 01:05 PM | #6 | |
Posted via Mobile Device |
04-22-2011, 01:06 PM | #7 |
3rd
04-22-2011, 02:05 PM | #8 |
Thx!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
04-22-2011, 09:22 PM | #9 |
A very light coat of high temp wheel bearing grease on the input shaft where the throw out bearing slides and also the splines where the disc rides.
Fuzzy |
04-22-2011, 09:38 PM | #10 |
Formerly- 1972SuperCheyenne
Thats what I do too.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
04-23-2011, 12:45 AM | #11 |
Will move to Burb forum...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-23-2011, 01:50 AM | #12 |
What?
I just dab a tiny bit of graphite on the pilot bearing, and a light brush of high temp grease on the input shaft where the clutch disc slides.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
