![]() Join Date: Jun 2004
gas tank vent
I pulled the gas tank out of my 71 2wd cause the gauge doesn't work and the tank straps were on backwards (some folks go to lot of trouble to do things wrong). There are two small (3/8?) vents (?) on the sides near the top. One on each side. Are these vents? Do they need to be hooked up? And to what? Any help appreciated. I'm dumb on gas tanks. The gauge problem was easy - no ground connection.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
Re: gas tank vent
Yep, those are vents that go to the container assembly (stand) that is located inside the truck next to the filler neck. That stand has three lines that come out of it: one for each side of the tank while the third goes to the charcoal canister. Do you have any of the lines left that go from the tank to the stand?
Also, check these out for a better explanation: What is this goofy thing? Fuel tank vacuum lines Last edited by 1949gmc; 04-22-2011 at 01:35 PM. |
Re: gas tank vent
Thanx for the info. I have nothing left of any of these lines. Guess I'll have to start from square one.
