Old 04-22-2011, 11:12 AM   #1
Adams74Chevy
Adams74Chevy's Avatar
Hand Choke Setups
I finally got my Q-Jet rebuilt this week and picked up a manual choke "kit" and was wondering if anyone had some pictures of your hand choke setups especially where you put the pull knob in the cab and routing the cable for the least binding issues. Also should I put the aluminum spacer back on under the carb that someone before me installed? The truck is stock so I don't know if it really makes a difference or not. The only reason I can think that it was installed is so the aftermarket air cleaner could fit over the HEI dizzy.
Adam
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 04-22-2011, 11:16 AM   #2
notyo_cheez
Re: Hand Choke Setups
You might be able to sneak the cable through the firewall grommet for the speedo cable, shortest distance between two points. Yes, reinstall the spacer.
notyo_cheez is offline   Reply With Quote
Old 04-22-2011, 12:51 PM   #3
tucsonjwt
Excellent decision. I have converted every square I have owned to manual choke. Now you can control the choke and know for sure when it is open or closed. You will have to tighten the set screw once every six months or so. The best way to use it is to depress the accelerator all the way to the floor, then pull on the choke knob, then keeping pressure on the knob - release the accelerator. This will set the choke all the way closed. If you don't keep pressure on the knob it will not close the last 1/32" or so. The choke cable goes through a grommet hole in the firewall just behind the left valve cover. (My rubber grommet is missing.) The carburetor spacer will help with starting when the engine is hot. It is normally used when an aftermarket carburetor (Holly, Edlebrock) is adapted for use on a Qjet (spreadbore) intake manifold. Here are some pics.
tucsonjwt is offline   Reply With Quote
Old 04-22-2011, 01:07 PM   #4
willstruck
Awesome, I was about to post this same thing. Just figured out yesterday that the e-choke i hooked back up didn't work. About to go manual
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
