04-22-2011, 02:47 PM | #1 |
Tubular Control Arms
Say I wanted to someday buy these for my 73 when I redo the front end. Seems there is no spot for the coil spring? Does that mean a coilover takes place? Also if there is anyone running this type of CA how do you like them?
Lower Upper
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
04-22-2011, 03:05 PM | #2 |
GoatLube Experss
Re: Tubular Control Arms
you can get em for coil spring's, coil over's or air bag's. most manufacture's make all three type's. I have some for my MonteCarlo that take the coil spring and a set for the Dually that take an air bag, however I have to be home to install either set.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
04-22-2011, 03:10 PM | #3 |
Those were from Summit. Where else can I get them?
04-22-2011, 03:33 PM | #4 |
GoatLube Experss
PorterBiult, DMJ, I know there are other's, mabey some else will chime in with more option's.
the PorterBiult ones are price'y, but they also center the front wheel's.
04-23-2011, 08:47 AM | #5 |
I had those arms and there is a spot for the coil spring. Right in the center of the lower arms. The spring sits around the tube sticking out of the lower plate.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
04-23-2011, 09:20 PM | #6 |
I have those same Lower and Uppers built by DJM and sold by Summit. It was cheaper to buy from Summit than directly from DJM. There is a place for the coil springs. Still have good ride height but I'm going to go another 2" lower using their coil springs.
