04-22-2011, 04:39 PM | #1 |
gmc leaf springs
need help from gmc guy's, does any one have picture of how there leaf springs are mounted. i need to know what the bracket that the u-bolts mount to look like. i know that my truck is not right and want to make sure that it right. thanks
04-22-2011, 05:46 PM | #2 |
Re: gmc leaf springs
Like this?
04-22-2011, 05:53 PM | #3 |
what year is your truck? that doesn,t look any thing like mine. mine is a 64 thanks
04-22-2011, 06:00 PM | #4 |
I didn't think they'd be different. I'm scouring the build threads for a 64 now.
04-22-2011, 06:15 PM | #5 |
None of these are terriffic, but they might let you see what you're wanting.
This one's a 4x4. Still looking for a 2wd |
04-22-2011, 06:20 PM | #6 |
2WD (thanks to Nachodog)
that's all I could find that was 1964 specific. If that doesnt work I'm sure someone else will chime in. Last edited by FetchMeAPepsi; 04-22-2011 at 06:21 PM. |
04-22-2011, 07:04 PM | #7 |
Registered Loser
Here's a pic from my 63 3/4 ton. Hope it helps.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
04-22-2011, 07:09 PM | #8 |
creep do you have a picture of the bracket where the u-bolts go yours looks like mine should be thanks
04-22-2011, 07:14 PM | #9 |
Registered Loser
Unfortunately no. I gave the rearend away to the guy that did the welding on my frame when I bagged mine. I'll try and find out if he still has them.
04-22-2011, 08:52 PM | #10 | |
ron Last edited by padresag; 04-22-2011 at 08:58 PM. |
04-22-2011, 09:40 PM | #11 | |
Hell yeah!!!
Stock is good but custom is the sh*t! Last edited by nachodog2; 04-22-2011 at 09:41 PM. |
04-22-2011, 10:28 PM | #12 | |
ron |
04-22-2011, 10:28 PM | #13 | |
ron |
04-23-2011, 07:10 AM | #14 | |
04-23-2011, 09:50 AM | #15 |
not trying to hijack or anything....but where did you GMC guys find replacement bushings for the leaf spring eyes?..... I have not been able to locate any.
Jared USMC 1st Battalion 8th Marines (95-99) 55 1st Series 3100 (on 98 sonoma frame) 65 GMC short bed fleetside big back window http://67-72chevytrucks.com/vboard/s...d.php?t=358493 |
04-24-2011, 06:03 PM | #16 |
the way my leaf springs are mounted is like the newer leaf spring trucks are done. i ordered new u-bolts for my truck and they came square on top to be mounted over the top of the springs. what i need is to see what the bottom plate looks like that th u-bolts mount to. heres pictures of how my rear end is mounted now. thanks
04-24-2011, 09:32 PM | #17 | |
By rondavid at 2011-04-24 the top of your springs should be square as they form over the top of your spring and connect into the brkts shown mounted under the axle ron |
04-25-2011, 10:16 AM | #18 |
Zero Albedo
My 64 1/2 ton:
Hope these pics help! Baz
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger Last edited by monolith; 04-25-2011 at 10:30 AM. Reason: Better Pics |
04-25-2011, 06:38 PM | #19 |
ok that is what i was looking for. now does anybody know where i can get the bottom brackets? thanks
