Old 04-22-2011, 06:42 PM   #1
low_84_inchaska
low_84_inchaska's Avatar
starting then dieing??
my motor was starting and running just fine...until i went to start it today and it starts and dies but if i feather the throttle it will blurp and pop...then die fuel pump sounds as it should
it has gas cause i just put some in it...the only thing that is different is i unhooked the factory gauges which i dont think would affect anything?
99 5.3....
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 04-22-2011, 11:50 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: starting then dieing??
Do you have a way of checking fuel pressure?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-24-2011, 02:25 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
check for vacuum leaks if it can't maintain idle, double check that the MAF is connected and reasonably clean. Both can choke a car out.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-25-2011, 08:02 AM   #4
low_84_inchaska
i checked fuel rail pressure-good
scanned codes-good
cleaned the maf
cleaned injectors
still starts then dies.
where specifically should i look for on the vacuum leak?
Old 04-25-2011, 11:38 AM   #5
low_84_inchaska
just realized my egr plug got blown out and was on the floor... could this be the culprit???
Old 04-25-2011, 12:42 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
the plug on the intake manifold, or the blockoff on the exhaust mani?
If its the intake then yes, thats a huge vaccuum leak introducing un-measured air into the manifold. I'm surprised it wouldn't throw a code, but not impossible.
Old 04-25-2011, 01:01 PM   #7
low_84_inchaska
plug on the intake manifold...the reason it didnt throw a code is that the egr is programmed out>??
Old 04-25-2011, 04:06 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ya, I would assume its acting like a giant vac leak. Even if the egr was programmed out, I would think all the extra air might trip another parameter, but who knows. Plug that up, and see what she does.
Old 04-25-2011, 07:59 PM   #9
85burb
85burb's Avatar
Some times engine has to be running for a certin amount of time to set a code or the ecm has to be testing for it. I would bet that is the problem but how did it come out?
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-26-2011, 08:04 AM   #10
low_84_inchaska
it twas the plug!!! runs like a champ!!
Old 04-26-2011, 08:26 PM   #11
85burb
85burb's Avatar
Yay!!!!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-27-2011, 01:40 PM   #12
low_84_inchaska
yeah i feel like an idiot.
