Old 04-22-2011, 06:50 PM   #1
Bakenaz
Bakenaz's Avatar
Inline 6 250 Crankshaft question
Sorry if this is a dumb question but here goes. Should my stock 69 crankshaft snout have threads for a balancer hold down bolt? New project for me and my daughter. Looking with a mirror found no threads in there. If there are no threads, how do you screw in the tool to install the balancer. Might be a mute point because keyway is stretched and new balancer simply slides on by hand. thanks
Bakenaz is offline   Reply With Quote
Old 04-22-2011, 07:46 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Inline 6 250 Crankshaft question
There is no threaded hole in your crankshaft. To install the balancer you have to tap it into place with a block of wood and hammer.
Old 04-22-2011, 09:02 PM   #3
68gmsee
Active Member
68gmsee's Avatar
If it slides in by hand it will slide back out. The balancer should be a tight fit. Most have to be hammered in as Tx mentioned. If you ever have it off at any time in the future have it drilled and tapped for a bolt.
If you get a new balancer be sure and remove the radiator.
68gmsee is offline   Reply With Quote
Old 04-25-2011, 10:06 AM   #4
Bakenaz
Bakenaz's Avatar
Thanks for the info. The new balancer just slid on. Too loose. The keyway is also stretched out. Looks like tie for a new crank or v8 time. Thanks for all the info.
