Thanks restorpro for the advice, will do. Have a new question about inserting a fuse link in a fusible wire. My alt has a 2 wire plug and a separate wire post. The 2 plug wires are labeled as such - an exitor (white) and the other (red) alt output. The hot wire alt output needs to have a fuse between the alt post and the hot post on the starter. Confused yet. What size amp fuse goes on this wire and where on this wire shall the fuse go. Thanks ez wiring.
The One And Only !!!
Re: wiring 73
Go to your local auto parts store, They should have a 5 1/2" to 6" long 14 gage fusible link wire with a eyelet on one end to fit the starter post. Then splice your alternator hot wire to it, That would be a cleaner more factory like way of doing it rather than a fuse.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
