Old 04-22-2011, 09:14 PM   #1
aztim1968
1968 chevrolet truck power steering conversion
Hello all, new to this so here it goes, I am thinking of installing power steering in my 1968 chevrolet c10. My question to you all is what exactly do I need to complete the conversion. I know I need the power steering pump,gearbox,and hoses. Is this an easy swap? Any and all help would be appreciated,
Thanks Tim
aztim1968 is offline   Reply With Quote
Old 04-22-2011, 10:34 PM   #2
blue betty
Re: 1968 chevrolet truck power steering conversion
Hi there, I just did this conversion in my 67. Besides the used gear box, rebuilt pump, new hoses, bolts, belt, pulley, new pitman arm and new rag joint (old one was destroyed taking it off, grinded the rusty bolts off much faster). Thats about all I needed pretty quick and simple installation. Took me about three hours with no air tools. Oh and I got an alignment done after as well. Runs great so easy to steer now, almost to easy one finger. I should have did this years ago. Good luck
1967 GMC Fleetside.
blue betty is offline   Reply With Quote
Old 04-22-2011, 11:11 PM   #3
aztim1968
Thanks Blue Betty, did you get your gearbox from a salvage yard or a parts house. I found most of the parts I need a O`reillys auto parts except the power steering pump brackets, do you know where I can find those brackets.
Old 04-22-2011, 11:56 PM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Why did you need a new pitman arm? I did the swap with the setup off my 68 3/4 ton onto my little swb. Didn't have to mess with the arm at all. Drives great. I just used the gear box and went with a much newer pump since I hate the res on the fender well. Was just curious.
prostreetC-10 is offline   Reply With Quote
Old 04-23-2011, 12:34 AM   #5
aztim1968
just got a quote from Eklers for a complete setup that includes pump,gearbox,pitman arm,hoses and new rag joint plus pulley for 804.00 including shipping. If anybody knows where I can find it cheaper please let me know.
Thanks Tim
Old 04-23-2011, 12:39 AM   #6
aztim1968
By the way, how do I post pictures of my truck on this thing? I still live in the stone ages
Old 04-23-2011, 01:36 AM   #7
5150.4.67
You might need to clearance the frame a bit, or space the power box out as it is a little bigger. I modified mine using some heat and a 5 lbs hammer.....
5150.4.67 is offline   Reply With Quote
Old 04-23-2011, 01:58 AM   #8
prostreetC-10
My Carbon Footprint
On my 68 it was a direct fit with zero issues.
Old 04-23-2011, 05:52 AM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
A 1967 frame is different and requires a spacer plate or homemade spacers (nuts) or a different style set up....68 and up is normally a direct bold on.
You will also need to check your engine block and make sure you have the holes you need to mount the pump.
I have done this conversion 10 times atleast and I have always bought complete set ups from board members, scrap yards, ebay, etc. I have NEVER spent more than $200 for a complete kit with pulleys. The only thing new I buy are the hoses.
DO NOT BUY Orieleys pumps and gear boxes...JUNK!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 04-23-2011, 02:09 PM   #10
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I've had my Orielly's gear box on since '07 without issue
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-23-2011, 03:10 PM   #11
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
My advice would be to seek out the parts either from a donor truck, salvage yard or a member on the forum. $800 is way to much, IMO. I did it to my '70 many moons ago. It's well worth it. I finally had to install a rebuilt gear box, today in fact, that I purchased from Advance Auto. They have them very reasonable right now. They're only $139+$45 core charge. At the moment you can get 15% off plus $50 towards your next purchase of $100 or more. That could go towards a pump.
Here's a link.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 04-23-2011, 06:16 PM   #12
67Slider
67Slider's Avatar
Anyone willing to post some pics of pulleys and mounting setup on this one? I am just about ready to do mine too. Could use some visual help.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 04-23-2011, 06:39 PM   #13
aztim1968
I just ordered the complete setup from ecklers it comes with all mounting brackets,hoses,pump, pitman arm, pulley,gearbox and new rag Joint. when it comes in I will take pictures of before,during and after pictures.
Old 04-24-2011, 12:05 AM   #14
67c10rustbuket
67c10rustbuket's Avatar
I got my PS conversion from donor parts trucks and im using a 95 serp setup not v belts, easily found at junk yards. 67 needs a spacer otherwise its straight bolt on. but hey if you got the money a new kit is the way to go.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-24-2011, 12:07 AM   #15
67c10rustbuket
click on "go advanced" below to the right to attach a pic.
Dan <---(my name)
Old 04-24-2011, 07:22 AM   #16
72freak
72freak's Avatar
It is my understanding that Orieleys went through a restructuring period and are now using some different vendors. I use them exclusevley and never had any problems with their parts untill about 2 years ago. YES!!! I have many many many parts that have held up but have had a string of bad ones recently. I have had 3 power steering gear boxes start leaking or stop working properly from different vehicles, LOTS AND LOTS of electrical parts go bad early...heck....last week I got a bad power steering pump, cam shaft possition sensor and another 3 month old Orieleys steering box stop working. I am now stuck because they have my core now so I have to keep going back. They offer $20 back for the inconvenience or to pay the mechanic to cjhange it again if you have a recipt from a shop.
Buy what you want from where you want....This is just my experience with them.
Old 04-24-2011, 11:19 AM   #17
chopnchaneled
chopnchaneled's Avatar
X's 2 If you have a early 68, I tried the spacer route, Didn't like it.
I was saved from myself by some fellow members here, there is a thread on it.
chopnchaneled is offline   Reply With Quote
Old 05-11-2012, 11:26 AM   #18
c10327
c10327's Avatar
Here's a link.
Hello I have a 1970 Chevy c10 , I am doing a steering conversion from manual to power steering . I have bought everything through my local advance auto parts like power steering box an pit-man arm , everything fits except the end of the pit arm the goes into the drag link ? to small an won't tighten up properly , the diameter of the stud that goes through the drag link is smaller than the manual steering pit arm . do you know the correct pit arm for my application ? Thanks in advance . Robert
c10327 is offline   Reply With Quote
Old 05-11-2012, 11:28 AM   #19
c10327
c10327's Avatar
Old 05-11-2012, 08:01 PM   #20
Old Yeller 1970
DON'T TREAD ON ME
Robert,
I did that conversion about 20 years ago so my memory is too fuzzy to recall the details with enough clarity to give you any guidance. I'm sure someone else will chime in that will be of some assistance.
James
Old Yeller
Old 07-05-2012, 03:15 PM   #21
poway
Hello: I have a 1968 chevy panel with "power assist". I'm referring to the kind that has the hydraulic cylinder between the frame and the linkage and uses a manual steering box. I'd like to convert it to a power steering gearbox and dump the hydraulic cylinder setup. It has the power steering pump and hoses. Anyone see any problems with just bolting up a rebuilt power steering box and reconnecting the hoses to it? AutoZone has Duralast rebuilt units for $125.00 + $45.00 core. Any advice would be appreciated. Thanks in advance.
poway is offline   Reply With Quote
Old 07-05-2012, 09:54 PM   #22
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
poway,the ram assist is a 67 only option.Later years used the power box.Yours may have been updated,installed by a dealer or on a 67 frame.Lots of possibilities.I'm not sure about the pump but GM wasn't one to redesign the mousetrap so I assume(keep in mind this is a guess) that the pump/brackets are the same as for a power gearbox.IIRC You will need the correct year pitan arm for the year model.You will probably need new hoses.The PS gearboxes up to about 1986 work,later ones are 3 1/2 turns lock to lock,earlier are 4 1/2 and seem mushy(my opinion) to me.The nut looking fitting on the back of the pump,that the large hose goes into is replaceable and can be used from a later pump.This may allow you to run factory hoses if you use parts all from the same year.Any hydralic shop should also be able to make hoses to fit your application.
Check your frame,where the gearbox mounts for an indention for clearance,you'll need to heat the frame and dimple it for the pitman shaft if it's not dimpled.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-05-2012, 10:15 PM   #23
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't think ALL '67 frames need spacers. I have a friend who has a '67 that he bought new. It was late in the model year. It had "armstrong" steering, but at his age (70+), he felt that power steering would be nice. So, he found a suitable donor vehicle and scabbed onto the parts he needed. No spacers were needed and now he's smilin'.
Member Nr. 2770
Old 07-06-2012, 04:12 PM   #24
kwmech
Make sure you didn't get an arm from a '71-72. tapers are different between drum and disc brake
Old 07-06-2012, 04:25 PM   #25
jablack
Classic Chevy Recycler
jablack's Avatar
I know on my 67 3/4 ton custom camper I didn't have to do any fab work or add spacers. I used a gear box from an 83 C10 and it bolted right on. The frame already had the dimple in it. And yes, it was the original frame.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
