04-22-2011, 10:23 PM | #1 |
panels
Im going to make my own rear side panels this week has anyone done them, Im thinking 1/2 inch plywood wraped in vinal..... any ideas
04-22-2011, 10:33 PM | #2 |
Re: panels
I am thinking about doing the same thing i was thinking high density particle board and matching carpet. Also wanted to build in speaker boxes only issue i see is may be a pain in the butt with double wall top.
04-23-2011, 06:37 PM | #3 |
Re: panels
thats why i was kind of thinking plywood so the speakers can mount up... but your right particle board would be easier to work with.
04-23-2011, 06:51 PM | #4 |
Re: panels
MDF would be much less likely to warp than plywood. I know Fuelcellguy was kicking around selling aluminum side panels at one point.
04-23-2011, 11:25 PM | #5 |
Re: panels
MDF? sorry not sure what that is
04-23-2011, 11:29 PM | #6 |
Re: panels
1/2 inch seems way to think IMO. I would go with 1/4" material of some sort. If you want to install speakers glue a piece of 1/4" or even 1/2" to the back of your panel in that area and that will give you plenty of material to mount your speakers too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-23-2011, 11:39 PM | #7 |
Re: panels
right on..... Im going to start them in like 2 days
04-24-2011, 12:11 AM | #8 |
Re: panels
Medium density fiberboard.....fancy name for particle board.
Posted via Mobile Device |
04-24-2011, 01:40 AM | #9 |
Re: panels
oh....duh...I knew that, I think ill use that stuff
04-24-2011, 10:29 AM | #10 |
Re: panels
1/4" plywood works best IMO. It fits pretty well against the screw piece in the back, and will tuck behind the "B" pillar or whatever you want to call it. Easy to work with, pretty light, and will hold shape over time IME. I would seal it with polyurethane before you cover it though.
04-25-2011, 12:11 AM | #11 |
Re: panels
what do you think i should seal it with
04-25-2011, 02:11 AM | #12 |
Re: panels
i used 3/4" plywood and routered the top so it tucks in on the top rail.its mounted using lag bolts with wing nuts on the back side so no visible mounting screws.
04-25-2011, 09:34 AM | #13 |
Re: panels
that looks prtty good
04-25-2011, 09:47 AM | #14 |
Re: panels
04-25-2011, 12:37 PM | #15 |
Re: panels
I used STARBOARD,
http://www.interstateplastics.com/se...FeJ95Qodoi78Dg. Very easy to cut to fit, will not rot. GOOD STUFF |
