Old 03-25-2003, 10:06 PM   #1
Porkchop
Porkchop's Avatar
camaro parts
I don't know much about suspension parts but am hoping to learn. I saw in the newspaper a 1970 camaro for sale that had disc brakes all around and a posi rearend, but the body was shot. Is it in anyway possible to make the frontend parts and/or the rearend fit under my 69. If it is possible would it take a lot of custom work? I am sorry if this question sounds stupid, and if it is, at least I don't have to be face to face with anyone when they laugh at me LOL.
Thanks a lot for any information
brad
Porkchop is offline   Reply With Quote
Old 03-25-2003, 10:21 PM   #2
chevy lover
HMMMM Chevy
chevy lover's Avatar
I don't know about the rear but the front, i would think would be to lite for our trucks. for front disks find a 73-75 suburban. you can pull the whole thing from the ball joints and just replace the ball joints in your truck to match the year suburban you take them from. the tricky part for me was the hoses.
68 Chevy C10 swb(under construction)
82 GMC K1500 6.2l diesel (daily driver)
77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________
Mike
chevy lover is offline   Reply With Quote
Old 03-26-2003, 05:16 PM   #3
Porkchop
Porkchop's Avatar
The reason I wondered about this was because I saw the whole car for sale for $400 dollars and it said it Had a posi with four wheel discs, but it had no engine or tranny and the body was shot. So I figured that a good posi alone is worth at least $300. I am setting up my truck to be lowered some and am putting in a small block, I wouldn't use the truck for hauling, would the front still be too light?
thanks for the response
brad
Old 03-26-2003, 06:05 PM   #4
jays68yak
jays68yak's Avatar
I think there is too much of a difference in the spindle hieght to even get it to work correctly. There rear discs should bolt on with out too much fabbing.
If the car is only $400 why not buy the brake kit from GMCpauls for around 500. and that comes with 2.5 drop spindles.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 03-27-2003, 10:37 AM   #5
Mike C
Mike C's Avatar
The first gen Camaros are a trailing steering arm setup while the second gen is a leading steering arm. No way to make this work. The A bodies (Chevelle, skylark, cutlass) use the same disc brake parts as a first gen camaro, but they have the bolt on steering arms swapped side to side because they are a leading steering arm setup. It is possible to put the second gen camaro parts on the a body with a set of custom aftermarket ball joints. You can do the A body brakes (69-72) easily on a first gen by swapping the steering arms side to side. The second gen Camaro spindle is a one piece assembly with the steering arms not removeable.
The rear axle is wider than the first gen, but it is possible to swap in. I've done a couple of 8.5" posi second gen axles in first gen cars. Requires a torch to get the old brackets off, an angle finder to setup pinion angle relative to the perches, and a reasonably powerful welder to re-attach.
In other words, unless their are some other parts you can use on the car, you are better off getting a 68-74 X body (Nova, ventura, apollo) for its disc brakes and rear axle. The X body sometimes had a mult-leaf 8.5" 10 bolt that will bolt right in to a first gen Camaro. It is an excellent axle, but the 8.2 is a POS. 73-74 are the best bet for 8.5 and disc brakes. The 75 and up X bodies use second gen camaro parts.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
