04-23-2011, 12:36 PM | #1 |
spindles and whith
I just finished mocking up my front suspension on my 65 sub. Control arms and drop spindles from 87 sub. Well I hung a fender and discovered that now my front end is wider than the stock rear dif. My question is, is there a way to narrow the front end back to stock whith? 1 1/2 rotors by the way. thanks.
04-23-2011, 03:55 PM | #2 |
Re: spindles and whith
Most dropped spindles will move your wheels out 3/4" per side. CPP modular spindles only move them out 1/4" per side. I know that's not what you wanted to here since it sounds like you already have your spindles but I dont know of any other way to give more fender clearance other than narrower tires.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
04-23-2011, 09:21 PM | #3 |
Thats the first thing ECE will tell you before you convert to disc...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
04-24-2011, 12:40 AM | #4 |
Resistance is Futile
Section out your control arms.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-04-2011, 02:48 PM | #5 |
I took the spindles to the machine shop and had them move the holes for the ball joints in 3/4 inch. Problem solved everything bolted back up perfect. No more four wheel drive look. Happy but poorer now.
05-04-2011, 03:30 PM | #6 |
Got pictures?
05-04-2011, 04:09 PM | #7 |
I think you will find the 87 front end was also 3/4" per side wider....
05-05-2011, 09:13 AM | #8 |
Slowbuild, I did not take pictures. I knew if I didn't I'd wished I had. What he did was make plugs for the old holes and milled new ones.
Kieth, I beleave the difference in width is in the spindles. I did not change crossmember only control arms and they measured the same lenth. It must be to make them the same as the rear dif. width. There must be others who have fixed this. I am not building a show outfit I just know what I want. |
05-05-2011, 09:31 AM | #9 |
OK, I had not realize that was where the width increase was, I am having the same problem u are with wheels, might look into machining it out......Thanks, Kieth
07-07-2011, 11:28 AM | #10 |
DSC00161.JPG Pictures of new ball joint mounted in new holes. Last edited by HERB; 07-07-2011 at 11:30 AM. Reason: no pictures |
07-07-2011, 12:03 PM | #11 |
I got my disc kit from pol with 1 1/4 rotors. Do these have the same problem?
07-07-2011, 12:09 PM | #12 | |
67-72 parts collector,…
The disc brake/drop spindle combo make it worse. Porterbuilt Fabrication sells 1" narrower tubular a-arms. CPP sells a 2" Modular drop spindle that will bring you back close to your drum brake width.
07-07-2011, 12:11 PM | #13 |
Same as all others with the exception of CPP's 2" Modular drop spindles.
07-07-2011, 10:46 PM | #14 |
after reading this thread i ran out to the garage and started measuring lol.i have ec's drop spindles,also got there 5 bolt replacement axles.front is 64 1/2'' rear is 63 1/2.is a half inch on either side a really big deal for tires?just asking.....just to understand,lolife you are saying that originally the front was a little wider than the rear?do you know how much?
07-07-2011, 11:07 PM | #15 | |
Senior Enthusiast
07-07-2011, 11:13 PM | #16 |
i see your point markeb01,i guess no wheel and tire purchases for me until truck is put back together.thanks dan
