Old 04-23-2011, 12:46 PM   #1
bigskydave
engine swap
Hi all, I have a 2001 silverado 4x4 1500 with the 4.8 auto. Does anyone know if the wiring harness would work with the 5.3 or 6 litre engine? Also, if it does, can I just get my ecm reflashed or would I have to get a motor specific. I would like to swap out the 4.8 for one of the bigger engines.
Is this doable or would it be a major expense and headache. Thanks for any help on this. By the way, I just joined and this is my first post. Hope someone out there can help me out with this. Thanks again and keep on playin! Bigskydave.
bigskydave is offline   Reply With Quote
Old 04-23-2011, 05:30 PM   #2
clinebarger
Re: engine swap
The harness will work, The 99-06 4.8, 5.3, 6.0 all interchange. If you get a DBW engine you will need to swap the intakes.
If you go with a 5.3, You can run a 4.8 tune with no problem. With a 6.0 I recommend getting a tune done. But will still run, maybe not to it full potential.
Swaping a PCM from another truck will not work, It has to have the correct VIN flashed in it
clinebarger is offline   Reply With Quote
Old 04-23-2011, 09:15 PM   #3
66redw/white
made in america
66redw/white's Avatar
Re: engine swap
thats it ^
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 04-23-2011, 11:30 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: engine swap
Clinebanger covered it. Highly recommend a custom tune.
EDIT:
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-25-2011, 01:38 PM   #5
bigskydave
Re: engine swap
Hey Clinebarger, thanks man. You seem to be up to speed on something like this, so let me pick your brain again. If I want to put in a 5.3 in place of my 4.8, do I have to change motor mounts, etc. Or would this be a fairly straightforward swap one out and one in? The reason I want to do this is I want to pull a travel trailer with my half ton.
Size of trailer is undetermined as of now. I have too much into my truck now and I would hate to get rid of it. I'll post a pic as soon as I download onto my new computer.
Again, thanks a lot. Dave.
Old 04-25-2011, 03:53 PM   #6
clinebarger
Re: engine swap
The motor mounts are the same. Its a VERY straightforward swap.
An engine swap will NOT increase the carrying capacity of your truck. Being a 1/2 ton will limit what size & weight Travel Trailer you can tow safely. Know the GVWR (Gross Vehicle Weight Rating) & GCWR (Gross Combined Weight Rating) of your truck & weigh the truck & trailer together before buying, Dont go by what a salesman tells you.....Hes there for one thing....$$$$$.
Old 04-28-2011, 03:59 AM   #7
60ratrod
yes, i do
60ratrod's Avatar
Re: engine swap
i think he's going more for pulling power
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 04-28-2011, 08:24 AM   #8
66redw/white
made in america
Re: engine swap
might want a 4l80 too...
sounds good
my old girl
Old 04-28-2011, 09:46 AM   #9
clinebarger
Re: engine swap
Most people using a 1/2 ton truck to pull a TT are overloaded. If you keep within the GCWR the 4.8 & 4L60E will be fine. This ratings SOLE purpose is not to "over tax" the drivetrain, Gear ratio has a big impact on this rating to.
