04-23-2011, 03:00 PM | #1 |
New rag joint needed?
Sorry, I know it's been asked but I am doing the power-steering conversion in my 68 and I have a 75 steering gear and i would like to know if it requires a new rag joint? It does because it is bigger right?
04-23-2011, 03:15 PM | #2 |
Re: New rag joint needed?
Just considering the age of the rag and having easy access during the swap I would say so. Especially when you see they are rotted as some are.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-23-2011, 03:26 PM | #3 |
There are different sizes of shafts. It will require a different joint if they dont match.
04-23-2011, 03:35 PM | #4 |
Got it, thanks. They are only around 8 bucks anyway so I will do it.
04-23-2011, 03:35 PM | #5 |
I thought there was definitely going to be a size difference.
04-23-2011, 04:19 PM | #6 |
For 8 bucks all you are going to get is a repair kit. If the shaft size is diff. you will have to find the correct one & then put a kit in it if ness. A new one is $40-50.
04-23-2011, 04:49 PM | #7 |
Who has them for sale?
04-23-2011, 04:57 PM | #8 |
Moderator
CPP sells the entire rag joint for $49. I believe they carry 3 sizes.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-24-2011, 08:54 AM | #9 |
Cool, ok. Thanks for the information. =)
