![]() Join Date: Mar 2011
Grooves in Rearend?
Has anyone ever seen this before? It looks like maybe the U-bolts were tightend down to tight. Wondering if I should chunk the rearend and get another or if this one would be ok to use?
Re: Grooves in Rearend?
wow to me that looks more like it had alot of movement in the rear end and the u-bolts was not tight enough to hold it in place and it wore it out where it rubbed. Least thats my opinion on the looks of it.
I dont think it would be an easy fix either way. and sure wouldnt be cheap. almost easier to go to your local wrecking yard and find another rear end.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#3 | |
That is much more likely from being too loose and wiggling around.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Yeah to loose is probably right. The other trailing arm perch on the other side of th rearend is a little wore out ok alot wore out. I was pretty sure that I should just get another rearend but didnt know if anyone had seen this before or not and if it would be ok? Anyways anyone want a 67 chevy truck 12 bolt rearend?
Moderator
![]() Join Date: May 2007
dang...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
braze it back up(fill) grind and it'll be good for another 40 years
Its a pretty deep groove and it has it on both sides.
Wow! I'm surprised that did not go all the way through the tube!
You may try CTC's Auto Ranch. The are just north of Denton right off of I-35 on the south bound side. They have around 15 to 20 67-72s. There also is another small salvage yard off of Collins road. They have several 67-72 trucks that are down to just the frame and suspension. The yard does not have a name. If you PM me I can give you directions or just take you there. Good luck! Keith |
yup, looks like the "u-Bolt was loose and over time, with vibration and all, just ate the rearend away, could have been worse and gone through to the axle... 8i just noticed mine were loose and tightened down on them both
LUCKY THE ubolt didn't wear, that be more of a mess
~Rest In Peace~
itlike a bAD tooth
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
the boat guy
I'd fill it and get new ubolts if the rest of the rear is good.
#13 |
18 Till I Die
x2
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#14 |
My Carbon Footprint
My rear end only has one big groove in it. LOL
#15 |
Redefining LowBudget
better look at your spid and find out if thats a posi ??? if it is I called it first!!! you can ship me that free rear end!!
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
