Old 04-23-2011, 04:30 PM   #1
Classicbigwindow
Panoramic Change
I would like to send a big thank you out to John Gilbert, Steve Bentley, and CCT for their tremendous window conversion article in the May 2011 Issue. I also want to thank all you Classic Truck Guys for your positive comments and genuine interest. Scott Hursh
Classicbigwindow is offline   Reply With Quote
Old 04-23-2011, 05:24 PM   #2
Slow Build
Slow Build's Avatar
Re: Panoramic Change
I was wondering if it was possible to make the small to big window conversion without changing the inside sheet metal. I think they made it look easier than it would really be. All I can say is you better have you cut template lined up pretty darn good before you cut.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-23-2011, 06:11 PM   #3
Classicbigwindow
Hi Rich, What I have found is that the inner cab metal behind the jamb at the lowest part of the window on the factory big window swoops deeper into the corner so you need a fill panel to reach the slightly larger radius of existing inner cab. Scott
Old 04-23-2011, 06:19 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
nice article.. interesting that you can either weld the outside seam and finish, or as they did just leave it with a flush gap.
Old 04-23-2011, 06:20 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum Classicbigwindow. Looks like you offer a very desirable conversion kit for the 60-66 trucks. If you have any interest in becoming a Forum Vendor, please let me know.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-23-2011, 06:38 PM   #6
Classicbigwindow
Thanks, John had mentioned that the next issue will show more progress and maybe glass install.
Old 04-26-2011, 09:26 AM   #7
John Gilbert
Next month's CCT does have part II. We held off putting the glass back in until after I took care of some surface rust and re-caulked the drip rails. I finished up with semi-gloss white paint on the roof. Now the windshield is back out and I'm painting the interior of the cab including the dash.
That story won't be in until after I've done a story on installing rack & pinion steering with a fast steering ratio.
And thanks again Scott, you do a real nice job of hand-forming the inner panel to convert to a BBW.
John Gilbert is offline   Reply With Quote
Old 04-26-2011, 09:42 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would really like to do this conversion, but $ and skill have kept me from it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
