Front end leans
Anyone know what would make the front of my truck sit crooked? The left side sits lower than the right in the front. Right now I dont have matching shocks on the front, the right has the factory style dual shocks and the left has one skyjacker shock that should be used with an aftermarket dual shock kit, but it leaned before I changed them. It used to be set up the same way but with the factory shocks, but I only had a single shock on both sides for a little bit and it still leaned. So no matter what I do with the shocks it wont sit normal. Could this be because the front leafs are worn differently? They are to the point where they are arched the oposite way they should be. The frame is also bent a little bit in the rear, but I would think that would make the back sit crooked not the front.
![]() 87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift 2000 silverado extended cab stepside 5.3l. Stock for now |
Local Redneck Authority
Re: Front end leans
The shocks are simple dampening the ride - they don't adjust the ride height unless they're nitro, gas or air charged. Better get the tape measure out and measure the frame and some common points down to the ground to figure out exactly what's going on. Could be a broken leaf that you may not see unless you take the spring ubolts and plates off.
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
Re: Front end leans
The side with two shocks on it has gas charged Monroes on it. The other side has a Skyjacker h7000 series on it, but that wouldnt explain the lean before I put those ones on. I will take a better loo at it today if I have time.
Re: Front end leans
Is it possible that one of the leaf springs has been changed(making them not match)
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Front end leans
It's not the shocks. Springs get weak and sag over time, but I would think they might tend to sag fairly evenly. I'd look closely for a broken spring as already suggested.
You also said the rear of the frame is bent. I wouldn't rule that out as a possible cause for the front to sit unevenly.
Re: Front end leans
I dont think they were, they both look as lod as each other and like they have been there the same amount of time.
Re: Front end leans
make sure the shackles are both the same and not stuck, ive had a shackle kick foreward or back and get stuck on one side making it sit lower on that corner.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
