Old 04-23-2011, 07:55 PM   #1
REEDS 72
REEDS 72's Avatar
New comer from Utah 1972 Chevy Big Block project
I bought this 1972 Chevy Nov. 09 after looking for a good project. Always loved this generation of trucks. Once you're into a project like this there's no turning back. This truck is all original drive train. It is a 2wd, 1/2 ton, 127 inch wheel base (and staying that way), 402 big block, 400 turbo tranny, 12 bolt rear end, ac cab, Cheyenne equipped.
Typical rust problems, as per most older Utah vehicles, did floor rust repair, replaced rockers and cab corners. I am trying to work from the inside out so I have had the inside cab painted as well as the top of the cab. I am staying with the original orange with white cab paint.
Power train completely rebuilt, motor rebuilt. Thankfully I have been able to find the parts I have needed. This is a work in progress and will still take a while to complete. These pictures show some of the changes and work that has been done.
REEDS 72 is offline   Reply With Quote
Old 04-23-2011, 08:30 PM   #2
Autoblueprint
Autoblueprint's Avatar
Re: New comer from Utah 1972 Chevy Big Block project
Nice job! Looks like you are taking your time and doing it right.
I'd suggest some POR 15 for the floorboards. It is a great product.
You may want to check out the interior section of my web site, might give you some ideas about insulation and sound dampening.
http://www.autoblueprint.com/1971_pa...index_nav.html
Keep up the good work!
Autoblueprint is offline   Reply With Quote
Old 04-23-2011, 09:16 PM   #3
mr.chevy
mr.chevy's Avatar
Welcome! Your truck looks nice. Did you do the cab repair or a shop? Cause that looks real good!
I also live in Utah.
Keep up the good work.
Ben
Its a 67 Chevy C10 now, and its short now too.
Here is my 1967 Chevy C10 Shortened Build Blog
http://boyescustoms.blogspot.com
Here is my 1967 Chevy C10 Shortened Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=433535
mr.chevy is offline   Reply With Quote
Old 04-23-2011, 09:16 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Good looking truck.. Welcome to the board from southern oregon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-23-2011, 09:31 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Welcome to the board and a nice project!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-24-2011, 04:42 AM   #6
pdxhall
pdxhall's Avatar
Things are lookin great, brother-in-law. You've made a lot more progress than I have. Happy to see you joined the site. There are great people here with tons of information and some great trucks. I'm looking forward to seeing more pics as you progress.
pdxhall is online now   Reply With Quote
Old 04-24-2011, 08:51 AM   #7
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
Welcome and Cool truck! Best of luck to you and your project!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 05-02-2011, 09:17 PM   #8
RCbowtie69
RCbowtie69's Avatar
Welcome from N.C., your truck is looking good
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 10-14-2011, 07:48 PM   #9
REEDS 72
REEDS 72's Avatar
I haven't posted for a while, but have enjoyed this site immensely! Been busy with the project. Installed a new brake booster and master cylinder. Went through brakes completely, excluding lines to be done at a later date. The existing lines seem to be holding strong.
After installing the rebuilt motor, had a rear main/oil pan leak. Pulled motor and installed new rear main one-piece oil pan gasket to exact manu. specs. At the same time, I installed 2400 RPM Stall converter, due to lack of power to the wheels. Reinstalled motor. Stall converter dead on! Made a major difference. Unfortunately, still having rear main/oil pan leaking problem. Frustrating, to say the least! This has set the progress back a bit. Eventually, the motor will be taken out again and the builder is going to install new oil pan, gasket and rear main to try to seal this up.
I'm going to move on for now and start disassembling the bed. I have found original replacements for the bed floor and drivers bedside, which I have had the body work done, already. Planning to have body work done on the rest of the bed pieces, reassemble and eventually spray-in bed liner.
Old 10-14-2011, 07:51 PM   #10
nick martorano
Nice! I hate oil leaks!
nick martorano is offline   Reply With Quote
Old 01-09-2012, 05:03 AM   #11
pdxhall
pdxhall's Avatar
Hey brother, how's the truck coming along? Any new pics to post?
Old 03-18-2012, 07:08 PM   #12
REEDS 72
REEDS 72's Avatar
A lot has been accomplished since my last post. I decided to go ahead and pull the motor.Took it to the builder and had a new one-piece oil pan gasket, rear main and new oil pan installed. Reinstalled motor and NO oil leaks. Everything seems to be fine. Motor is running like a champ!
Went forward on tearing my bed apart, as planned. Decided to do a frame resto at the same time. Thanks to this site, I was able to locate some trailing arms in excellent condition, from a member. Removed cross members and other frame parts, due to corrosion, and had them media blasted. Used POR 15 on all frame parts, rear end differential, and reinstalled everything with grade 8 nuts and bolts.
Put on new lowering springs, new brake lines at the differential, and finished reassembling frame and differential. Previously had body work done on all of the bed pieces, just had to put it back together and reinstall new back bumper.
With warm weather approaching, the project will probably slow down, but I amwanting to get some body work done on the doors. Need to save time for car shows and swap meets.
Old 03-18-2012, 07:21 PM   #13
REEDS 72
REEDS 72's Avatar
More pictures and frame "before".
Old 02-05-2013, 06:42 AM   #14
pdxhall
pdxhall's Avatar
Okay brother, it's been almost a year since you updated this thread and I know you've done a lot to your truck. How about an update. You know what they say,
Don't make me come down there a kick your A$$.
Old 02-05-2013, 06:55 AM   #15
daves72C10D
daves72C10D's Avatar
Nice truck. Yea, lets see some more picts.
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 01-08-2014, 06:46 AM   #16
pdxhall
pdxhall's Avatar
It's been almost a year since any updates and I know this truck is almost done.
Do I need to buy you a new camera?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
Old 05-19-2014, 01:10 PM   #17
REEDS 72
REEDS 72's Avatar
Here is the most recent update. The pictures show the rest of the frame being finished. All of the frame and surrounding suppension parts have been hand painted. The motor and transmission has been reinstalled. Original exhaust manifolds have been ceramic coated. Cab has been prepped and painted.
Old 05-19-2014, 01:26 PM   #18
REEDS 72
REEDS 72's Avatar
It's off to final body work and paint. More pictures to come.
Old 05-19-2014, 01:48 PM   #19
BADAZ chevy guy
BADAZ chevy guy's Avatar
Looks really good so far.
What part of Utah? I'm in Clearfield!!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 09-14-2014, 11:08 PM   #20
pdxhall
pdxhall's Avatar
Hey brother, how are things going? I am surprised you haven't updated your thread, I know you've got that rig painted and finished up. Well, they are really never finished. You need to let these guys see that beautiful truck.
Sanity'66
Old 11-23-2014, 10:33 AM   #21
Jahloha
Jahloha's Avatar
Alright Reeds, looks like Im gonna have to get my fix of your truck by driving down and checking it out!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-23-2014, 10:59 AM   #22
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Looks great so far!
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-04-2015, 10:19 AM   #23
REEDS 72
REEDS 72's Avatar
Truck is painted turned out real nice still doing some small things lowering the rear some more. Down the road changes I am going to do is aluminum heads air - gap intake and EFI also looking for new project keeping my eyes open for1950 era chevy cars or maby 67/72 chevy trucks my 72 has been a blast
Old 01-04-2015, 10:23 AM   #24
Jahloha
Jahloha's Avatar
Reeds, looks awesome! You do the painting yourself?
-JASON
Old 01-04-2015, 11:36 AM   #25
Malamute
Malamute's Avatar
That turned out very nice! I grew up in Springville and I'm familiar with those old payload stickers......you should have kept them on it!
Malamute is offline   Reply With Quote
