04-23-2011, 08:10 PM | #1 |
throttle pedal???????
i got an offer today to trade my blazer for a 69 chevy 1 ton 4x4, dana 60 front,14bolt rear, turbo 400/205, all running gear out of 1986 1ton, new paint, few touch ups needed, brand new wheels still in boxes, new bench seat, factory tach, all new chrome, but the guy im trading says i have to change the throttle pedal assy to work right with that trans, any info help pics are a bonus
Lowered 2002 PT Cruiser ONLY for mileage. 1969 Stepside 4x4 ( under construction ) |
04-23-2011, 08:35 PM | #2 |
PROJECT 7DEUCE
Re: throttle pedal???????
I believe the 69 has the rod set-up and the newer trucks have the cable set up? I could be wrong though as all I have ever owned are 72 models.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-23-2011, 09:42 PM | #3 |
Between Trucks...
The '69 would be a throttle rod setup. He might be talking about getting the electric kickdown for the TH400 to work. A Lokar setup will work for that with the throttle rod. You need there carb mount for the kick down as well, probably about $125 total cost involved.
Beat it to fit, Paint it to match... |
04-23-2011, 11:46 PM | #4 |
thats the exact answer i was looking for thank you very much, Lokar has everything i would need?
04-24-2011, 01:00 AM | #5 |
its all about the +6 inches
in reality, you can go 100,000 miles without the kickdown. It only controls kicking the tranny into first, it'll do a 3 to 2 downshift without it.
Now it it has a cable kickdown, and is only a 3 speed, then it is a TH350 and it should be hooked up. You can still go 100k on it without, but it does benifit more than just on the passing gear. |
04-24-2011, 11:11 AM | #6 | |
Between Trucks...
Here's a couple of pics before I redid my motor:
04-24-2011, 03:56 PM | #7 |
thanks for the pics, gonna be real helpful
04-24-2011, 08:54 PM | #8 | |
Sorry...not trying to Hijack the Thread. It was just intyeresting to see the responses.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
04-24-2011, 10:48 PM | #9 |
your cable either needs adjusted, or you have too steep a rear gear and kicking it into second at 50+ would run the RPMs too high
04-24-2011, 11:07 PM | #10 | |
I run about 2200 RPM at 55 MPH.
