Old 04-24-2011, 10:42 AM   #1
cardreams
hey guys will these rims fit our trucks
hey guys iam looking at geting these rims there 20" was wondering if they would work on my 68 c-10 i have a 3 1/2 5 drop on the truck
cardreams is offline   Reply With Quote
Old 04-24-2011, 10:47 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: hey guys will these rims fit our trucks
they'll probably physicly bolt on... but they'll be tucked in too much and you may not be able to turn the wheels all the way
Old 04-24-2011, 10:56 AM   #3
cardreams
what if i change the tire size ?
Old 04-24-2011, 11:15 AM   #4
cardreams
is there anyone running these rim now?
Old 04-24-2011, 11:57 AM   #5
Longhorn Man
probably won't help much. Can you get a pic of the back of the wheel? It's not so much the tire, but the location of the wheel in the fenderwell. If the back spacing is not right, and the wheel is tucked in too much, it won't work very well. You could get spacers, but you would be better off getting wheels that fit properly.
Those look to be late model rims, and that is the problem. New cars require different backspacing than old ones. New cars look like the wheel is flat (as looking from the outside) while old cars need deeper dish rims.
Old 04-24-2011, 02:03 PM   #6
OJ1988
Just a car guy
OJ1988's Avatar
Yeah need backspace measurements.
If thru are local, the guy should let you try and fit one on the truck.
I've had people give me a deposit and take one wheel with them to try, or drive teir car to me and test one.
If they have a lot of bs, as others said you'll need spacers. Bad thing about 67-69 is the narrow rear, it makes more of an issue.
On my 69 stepside, 4.75" is as much bs as I can fit
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 04-24-2011, 08:41 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
the other question will be the hub. Looks like those were on a late model truck judging by the tire size....so likely the hub bore is too small...that can be machined but something to consider.... (or you can install a small spacer to clear the hub)
Also, the tires being so large will be overly large for your truck and might rub with your drop and definitely will make the speedo be way off....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-24-2011, 09:34 PM   #8
OJ1988
Just a car guy
OJ1988's Avatar
Tires are big, they look more like a 17 or maybe 18
1973 Vega Drag Car
1970 C20 tow rig
