Old 04-24-2011, 01:15 PM   #1
roofingbloke
Questions.
I have recently removed my 250 v8 from my truck along with the 4 speed box, i will be replacing with a 350 chevy and a 350 th box,
My questions are,
1. the small crossmember that holds the park brake cables, will it need re positioning with the different gearbox,
2. my propshaft is a two piece, should i just shorten this or go to a one piece.
I have a 63 long fleet.
roofingbloke is offline   Reply With Quote
Old 04-24-2011, 07:44 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Questions.
You shouldnt need to reposition your tranny crossmember, use the stock perches. the driveshaft will need to be cut or lengthened but you wont know how much until you get the motor in. also this would be a good time to replace the carrier bearing too.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
