Old 04-24-2011, 08:00 PM   #1
68c10rat
Questions about a five lug deal I found
Ok, I have found a full five lug swap,front and rear. The guy is looking for $400 all of it,he said he would drop the k member and give me the whole deal,and he would drop the full rear axle and give me all of that. Now I am planning on bagging this truck so that is basically the question,does it matter what year this is under b/c it looks like mine,it just has a set of z71 wheels on it,which I would get rid of in favor of a set of rally wheels with the smooth centers. He also has a decent cab that I am going to purchase as well. What do you guys think though,is this good or right on as far as price?
thanks
68c10rat is offline   Reply With Quote
Old 04-24-2011, 09:09 PM   #2
tasian
tasian's Avatar
Re: Questions about a five lug deal I found
what kind of shape is it in? if it doesn't need anything its not a bad deal you said it looks the same? what kind of truck is it off of?
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 04-24-2011, 09:12 PM   #3
71swb4x4
71swb4x4's Avatar
Z71 wheels are 6 lug.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-24-2011, 09:37 PM   #4
68c10rat
I think he said the five lug setup was off a 70-71,something along those lines.It would need new rotors or have these turned. My truck is a 68, but I am about to buy a decent cab which I think is a 69-70. I am going to keep my 68 front though with 67 fenders.
The setup looks like mine on my 68 except it is 5 lug
Old 04-25-2011, 12:31 AM   #5
tasian
tasian's Avatar
well your gonna want to find out for sure what year it is so you can get the right parts for it IMHO unless all the balljoints and bushings are good you could find a better deal and get a rebuild kit for the front end but it depends on how soon you need it and how much you wanna spend kinda thing
Betsy's build
Old 04-25-2011, 03:06 PM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
shoot, if you were in Houston, Texas, I'd give you my stock drum setup... Im holding it for someone who wants it... maybe next year i will chunk it.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-25-2011, 08:22 PM   #7
68c10rat
Well I was going to offer the guy $300 for the whole setup but wants $475 for it now. He says I will have to pay him to take it out. Whatever,I'll keep shopping. Still looking for a cab too. I think I may go to a local u pull it here where I live. What year should I be looking for to get disc brakes? I want to run some decent wheels and maybe bag or at least lower it.
Old 04-25-2011, 09:06 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Tell the guy to kiss off with that attitude. Get on Craigslist and locate a 73-87 truck (up to 91 on Burbs) for a donor. Try to buy the suspension components, or buy the entire vehicle if its cheap enough. Rob what you need, and sell the rest.
Read this for some more insight- "Drum to Disc" conversions 67-70"
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-26-2011, 06:35 PM   #9
68c10rat
Ok so I read over the info on that stickie,I want to mkae sure that I understand before I commit. I can basically roll the entire front end out from under a 73-87 truck/suburban 2wd and it will bolt up to mine with no problem. I just need to know the year I am pulling from to make sure I can replace the worn out stuff on the "new" front end. I will have to rework the brake lines but that is a different day. Does this sound right? Am I on the right track? I am going to walk the pull a part yard here where I live Saturday and try to find some stuff.
Old 04-26-2011, 08:39 PM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
you are correct.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-26-2011, 08:56 PM   #11
68c10rat
Cool,thanks. Now it I just have to get out there and see what they have. Is it only the four bolts on the top to remove the entire front end from a donor truck? What in all do I need to get when I roll the front end out? Do I need to get anything else off the donor truck?
Old 04-26-2011, 09:07 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Get as much as possible.
If you can,... have them cut the frame right behind the crossmember.
This way you can unbolt the master cylinder and get all the steering linkage, steering box, steel brake lines, sway bar, etc.
I bought my last setup (years ago) from a guy that builds pickup bed trailers.
I got the whole front section for $75.
Keith
Convert to disc brakes.
Old 04-26-2011, 09:11 PM   #13
68c10rat
Ok from the sticky 67-70 installing 73-87 crossmember,it says to grab the steering box, center link?not real sure, and idler arm??not real sure of that either. So does someone have pics of what I am snatching off of this truck or trucks. Im also going to try and pick up a rear end,I can get that from the same truck I presume? How could I get disc on the back or is that going to be a lot of trouble??
Old 04-26-2011, 09:14 PM   #14
68c10rat
That would be nice. Im not sure if they will let me do that but I will definitely ask/try. I would love to make it easy. I probably wont be able to pick anything up that cheap with the popularity of these trucks today.
Old 04-26-2011, 09:16 PM   #15
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
At the rear, anything past '72 is leaf spring and not a direct bolt in. The '71-'72 rears are 5 lug and 3/4" wider each side (1.5" total) than your '68. A '71 or '72 donor would give you front and rear 5 lug with discs up front. Up front as you've discovered there is more choice in model years that bolt in.
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-26-2011, 09:34 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
For the rear, you have a few choices. You can have your axles redrilled, or buy replacement axles. Some of our Forum Vendors offer them as well as Moser. You can also replace the entire axle with a 71-72 as mentioned and its a direct bolt in although they are wider. Once again the 73+ donor truck can provide you with an axle as well, but they are all leaf springs, and no provision for panhard bar.
If you want rear discs, you will need to look at aftermarket kits. Captfab sells a really simple kit, that might be of interest. Several of our Forum Vendors offer various brand kits, so you will need to research that option as well.
Articles-
"Refining Sierra"
