Old 03-26-2003, 12:33 AM   #1
red72chevy
flamethrower exhaust
tell me... anybody ever put a flamethrower in their exhaust. if so how hard was it and can you order them from like autozone or pepboys?
thanks a lot
red72chevy is offline   Reply With Quote
Old 03-26-2003, 01:11 AM   #2
pissonNOS
senior member
pissonNOS's Avatar
AUTOLOC has a kit for around 120$
check truckstv.com they did one on there
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 03-26-2003, 01:19 AM   #3
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I haven't done it, but I've seen kits. I was thinking of a variation on the flamethrower. I was thinking you could mount a injector before the spark plug and use propane! Hopefully it wouldn't explode!
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 03-26-2003, 08:55 AM   #4
Blue Beard
Blue Beard's Avatar
Have to get back to you on this one......Looked at a site that if I remember right had all the parts needed thru your local Radio Shack......very inexpensive......
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-26-2003, 10:12 AM   #5
dubie
dubie's Avatar
I talked to my dad about the propane thing the other day, seeing how he has been in the propane business for 36 years now. He told me it would work with propane and you would get a bright white to blue flame from it. Just because propane burns at such a different temperature that gasoline. I am still thinking of the flame throwing kit for Project Flatbed. All you need is a 2 button box, 2 coils, and a couple spark plugs.......i think
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-26-2003, 10:23 AM   #6
dubie
dubie's Avatar
Here are some cool pics I found
http://www.gotflames.net/photos.htm
There is also a kit on this page you can buy for about $80
Old 03-26-2003, 12:59 PM   #7
Blue Beard
Blue Beard's Avatar
Thursday Night Garage Assoc. - Flame Thrower
type this site:
Flame Thrower - DIY
Look under Tech
select Electronic Flame Thrower
looks like computed instructions with part numbers to built your own............
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 03-26-2003, 08:15 PM   #8
Reumster
L.E.D. Freak
Reumster's Avatar
Yeah great! as if I don't get pulled over anough at it is! LOL
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-26-2003, 08:27 PM   #9
>X<
registered IWATA user
>X<'s Avatar
my friends dad has a 60 something pink cadillac with flames, it doesnt go though the engine though, like regular kits, he has a seperate switch that squirts gas out a nozzle in the tip of his exhaust. it throws fire at least ten feet and it throws it onto the ground,ground burns, pretty cool
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 03-26-2003, 08:31 PM   #10
Reumster
L.E.D. Freak
Reumster's Avatar
I just wonder how safe this is. My gas tank is in the back. What if the system has a leak? or the flame back feed into the system?
(406)675-8082
Old 03-26-2003, 09:30 PM   #11
>X<
>X<'s Avatar
i have always wanted this, and now that i have a welder it would take me a couple hours to do the exhaust work i have turndowns after cab though, so i would have to route pipe out the back or sides. how dangerous is this with a fuel cell? does the exhast sysem haveto be fully welded or can it be clamped in some places? it would be so friggin cool to have this at school. about how long does it take to do this install?
Old 03-26-2003, 09:31 PM   #12
>X<
>X<'s Avatar
how bad is this for your motor? trucks tv said that all you have to do is change your oil more often
Old 03-26-2003, 09:34 PM   #13
red72chevy
well guys i saw the thing on Trucks on TNN. the flame only is in the tailpipe and doesnt go through the whole pipe. there are some kits that use propane and are really dangerous. so it isnt that dangerous except for the dumb 17 yr old rice burner tailgating you. so why dont we just show him who to litterally have a rice "burner" :-D
Old 03-26-2003, 09:40 PM   #14
>X<
>X<'s Avatar
i dont get it, it says on GOTFLAMES.COM that the kit is 80 somehint, and then plugs, wires, and coil, but then it says in the directions below that it will cost about 500 for everything. whats up with that?
i'm thinking of just making a bolt on exhaust extension that exits under my steps that i can take on and off if i end up ordering this.
Old 03-26-2003, 10:52 PM   #15
rage'nrat638
rage'nrat638's Avatar
THANKS FOR THE INFO GUYS
rage'nrat638 is offline   Reply With Quote
Old 03-26-2003, 11:58 PM   #16
>X<
>X<'s Avatar
i'm seriously thinking about this now, i have enough extra pipe to makle a bolt up piece that exits under my steps, and clamps on. all i would have to do is put a quick conncet on the wires and i could take it off whenever i wanted. hmmmmm
Old 03-27-2003, 12:26 AM   #17
LudwigTheMad
LudwigTheMad's Avatar
This can be done really easy....drill and tap exhaust about 6" from the back of tailpipe...(might be for).soo you can put a spark plug in it. run spark plug wire to extra coil mounted and Grounded on framerail......run 12 guage wire to switch in cab, run 12 guage wire to batt +...
start car, flip switch, adjust choke to run a little rich......wooosh flame on......works best with manual choke, or if you know your going to do it adjust carb to run rich...hit the button when you want flame (this was can be a little hard to get started as depending on how rich your running the plug can foul out.
stock coil out of junkyard, $10
hole drilled and tapped by friend (who happened to have the @!#$% tools).......6pack
single pull, single throw two pole toggle switch from Radio Shack..Less than a buck
exta wire laying around garage from last project ......Free
The look on the punk ass kid who drags his hands all over your fresh detail job as his pants catch on fire....priceless...
For the really important things in life there is "Ludwigs Insanity" (widely accepted at most Mental Hospitals world wide) for everything else....cash....
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 03-27-2003, 04:09 PM   #18
>X<
>X<'s Avatar
whats the black box that the kit has?
Old 03-27-2003, 04:10 PM   #19
>X<
>X<'s Avatar
what exactly does the switch do? cuts off power to the coil? why do you need another coil?
Old 03-27-2003, 05:14 PM   #20
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
As if I didn't have enough going on, now I have something else to add to my list. Let's see... fertilize lawn, paint garage, give dog a bath, make fire shoot 15 feet out the back of the truck...
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 03-27-2003, 05:44 PM   #21
rage'nrat638
Thumbs up IF THE COPS PULL YOU OVER LIGHT HIM UP
torch the sucker
Old 03-29-2003, 02:50 AM   #22
LudwigTheMad
umm....black box..don't know, extra coil is needed because you don't exactly have an exta spot on the one for you engine.....unless of course you are a master of the "dope smoken old man" technique of making and installing a extra spot on your distibutor......
the switch is so that you can control WHEN flame shoots out the back end....after all you don't want them to light up EVERY time your engine runs a little rich....
Don't light the cop up....just his car....make sure you do it when he is at your window-and make a farting noise with your mouth when you do it.....don't forget to say "excuse me"
Old 03-29-2003, 12:07 PM   #23
>X<
>X<'s Avatar
so why is the kit better than just building it yourself? what exactly do i need to buy. i already have all the pipe for the system, i mgiht have a coil laying around too. can someone post up a diagram of how to wire this thing up? thanks, guys. we have 20 days leftof school and i want the half primer 71 to shoot fire, thatd be so bad ass
Old 03-29-2003, 12:08 PM   #24
>X<
>X<'s Avatar
Ludwig, are you talking about building a kit that jsut lights the exhaust or the kit that cuts off power to the exhistin coil so the gas cycles through your engine and then lights?
Old 03-29-2003, 01:24 PM   #25
casey
casey's Avatar
ludwig your theory is ok,....... but the one that I seen that works best is , hang a midget underneath in a cage with a bic lighter, and two tiger torches
casey is offline   Reply With Quote
