Old 04-24-2011, 10:14 PM   #1
rchadhaney
Parts for 80' Silverado Engine
I'm fairly new to this site (as a poster, not a reader) I am finally getting around to ordering parts for my truck to get it back on the road again.
Specs:
350 bored 0.30 over
mild cam
Edelbrock performer intake and carb
Questions:
1. What fuel pump do I go with?
http://www.summitracing.com/search/D.../?Ns=Price|Asc
2. Truck has been sitting a while, what all is recommended to getting the brakes where they are safe?
3. The a/c isn't working and I will want that. I know my compressor has a leak in it. The condenser is good but the drier won't be. Where should I go to get a good condenser for cheap, go with a reman? What else should I buy for it other than the compressor and dryer?
4. Truck is a Silverado with almost all the options however it doesn't have intermitten wipers, what does it take to add factory intermitten wipers? is this just a switch or is there more to it?
Thanks guys for all of your help.
1997 Chevrolet 2-door Tahoe
1980 (LWB soon to be SWB) 2wd.
rchadhaney is offline   Reply With Quote
Old 04-24-2011, 11:36 PM   #2
rayfinseats
Re: Parts for 80' Silverado Engine
1. Go electric fuel pump. Todays gas sucks.
rayfinseats is offline   Reply With Quote
Old 04-25-2011, 10:45 AM   #3
bmchevy1979
bmchevy1979's Avatar
Here you go take your pick
http://www.summitracing.com/search/M.../?Ns=Price|Asc
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 04-25-2011, 12:32 PM   #4
85gmcguy
Plays with trucks
85gmcguy's Avatar
RockAuto.com has pretty good prices on A/C parts. Get a dryer, compressor, and a metering orfice at a minimum. Adapter ports if it hasn't been converted to 134 yet. I pulled my evaporator and it was pretty dirty. I washed and hosed it off good. (see my Defroster Debacle thread). I haven't finished charging mine yet, hopefully this week. Good Luck!
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 04-25-2011, 02:47 PM   #5
rchadhaney
I've never bought anything from RockAuto before, prices seem decent. I found a four seasons reman ac compressor on Ebay for 85.xx is that a good price? comes with a 6 month warranty.
what is the metering orfice, where is that located at?
Thanks for the info.
Old 04-25-2011, 02:48 PM   #6
rchadhaney
Can anyone suggest an electric fuel pump and tell me why I should go with the eletric or the mechanical pump? How good are the Mr. Gasket fuel pumps?
Old 04-25-2011, 03:56 PM   #7
85gmcguy
Plays with trucks
85gmcguy's Avatar
RockAuto is great, I've bought tons of stuff from them and if you do a quick search you could find a discount code for 5% off. I have my stuffed shipped to work 'cause it's cheaper. Unless it's a "name brand" company I tend to shy away from ebay for new parts. I'll see if I can post a picture of the orfice and location later this evening. It's not rocket science, just kind of a PITA.
Gary
My Dad's Old Truck
1985
Old 04-25-2011, 07:57 PM   #8
85gmcguy
Plays with trucks
85gmcguy's Avatar
OK, first picture shows location, it is the bottom (high pressure) line into the evaporator. Second picture shows correct orientation of the tube. third picture has part number (AC-Delco). They can be a pain to get out, sometimes needle-nose pliers will grip them, but I usually use hemostats.Hope that helps.
Gary
My Dad's Old Truck
1985
Old 04-25-2011, 09:14 PM   #9
rchadhaney
Oh, wow thanks I didn't even know that part existed. I appreciate your help on this. any input on fuel pumps?
Old 04-25-2011, 09:44 PM   #10
85gmcguy
Plays with trucks
85gmcguy's Avatar
http://www.summitracing.com/parts/CRT-P4070/
If you want an electric, these are good. I use one with no problem. If you want a good mechanical, try a Carter from RockAuto. You shouldn't need anything "trick" (hi pressure/hi volume) just a good dependable piece. Just my .02.
Gary
My Dad's Old Truck
1985
Old 04-25-2011, 10:17 PM   #11
rchadhaney
Well I just got done spending 150.xx at rockauto.com Their prices are pretty good compared to Autozone. I ordered all of the a/c stuff except the compressor from their and a new power steering pump (mine is a hydroboost and the outer casing is bad). Thanks for the tips.
