Old 04-25-2011, 04:12 AM   #1
bignbad
bignbad's Avatar
voltage regulator
What cause a external voltage regulator to go bad with in 2 months?I got it form napa if anyone asks.She's not charging the Battery.Put a new one in and its fine.But I dont think they should go bad in a month or two.....
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 04-25-2011, 05:16 AM   #2
Jeffs70
Jeffs70's Avatar
Re: voltage regulator
If I am correct here the voltage Regulator on our trucks should not ground to the body of the truck. I remember years ago I changed mine and all the screws had to be replaced because they are rubber coated? and if they touch the body it can cause problems? least that is my two cents but I could be wrong.
also make sure about corrosion in the fuse box and on the fuses. a good ground from the frame to the body. just some tips maybe to look for. hope these help.
Jeffs70 is offline   Reply With Quote
Old 04-25-2011, 05:35 AM   #3
JimKshortstep4x4
I have had good luck with the original Delco regulators but very poor luck with the new ones. I don't buy new regulators for the same problem that you had. They don't seem to last. If one of my regulators go bad I replace it with another used one, (which is seldom). The other option is to replace the alternator with the newer internal regulators which works out well.
The original regulators have a ground wire from the regulator to the radiator support and without the ground the regulator will not regulate properly. The rubber mounted screws are for vibration reduction.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-25-2011, 10:26 AM   #4
cdowns
cdowns's Avatar
good grounding is essential from regulator to core support and also the ground from core support to the frame// new stuff has crappier contacts and a poor or partial ground will cause them to burnup quick
