04-25-2011, 06:49 AM | #1 |
transmission swap - 3 speed to automatic
i am considering changing from a 3 speed to an automatic. anybody know which transmission would be compatible without having to change the driveshaft? I have a 71 c10 with a 307. would a short tail th350 work? thanks!
04-25-2011, 07:23 AM | #2 |
Redefining LowBudget
Re: transmission swap - 3 speed to automatic
yep that would do it but unless you own it then look for the 200r OD trans you'll be much happier
04-25-2011, 09:37 AM | #3 |
04-25-2011, 09:43 AM | #4 |
Its a direct bolt in your going to have to put in a switch for the lock up torque converter but thats and easy thing to do..the 700r is a bit longer the way I understand it which means you have to cut the DS
04-25-2011, 10:19 AM | #5 |
