14 bolt rear brakes questions???
Got a 88 one ton dual rear wheel CC. I can not get my hand in to even touch the rear brake bleeder fitting because the rear springs are so close to the brake backing plate. The wheel cylinders and all the line must be replaced after a hard life up here in the rust belt. How do you work on the rear brakes? Looks like I have to remove the rear springs. Is this true or is there some secret????
Next!
![]() Join Date: Jan 2003
Re: 14 bolt rear brakes questions???
Pull the hubs and then the axles. Of course with all the rust in our area you may need some friendly persuasion ( a sledge) if you know what I mean. there's no way you should have to remove the springs to do any of the rear brake work.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
#3 | |
...Hope this helps, Joe Posted via Mobile Device |
#4 | |
Next!
| Bookmarks |
