![]() Join Date: Apr 2011
another newb question:
how much would you estimate it would cost to get this truck up and running again? just looking for a ballpark estimate............ -1966 1/2 ton truck is complete. only thing missing is the gas tank. (had gotten rusted out and then removed) -had been fully restored, was running when parked 7 years ago. -350 engine, 400 automatic transmission, aftermarket a/c. Last edited by chimney chop; 04-25-2011 at 01:00 PM. |
Re: question.....1966 GMC sitting out in the elements for 7 years...........
I'd be afraid to guess. It may just take a hose, a can of gas and a battery or every wire could have been chewed up by rodents...there's alot of information missing. Pictures would help also.
Martin Gibson
USAF Retired 1964(-ish) C10 |
here's a pic of the engine
shouldnt be much if it was already restored put new tank an fuel line on an give it a try an see if it starts. may need to rebuild carb an replace all old fuel filters
I have car A.D.D.
I'd say somewhere between $100 & $100,000 depending on how detail oriented you get with it. At least a ballpark figure for ya.
![]() Really though. I agree with starting with the known stuff and follow up from there. I have to do the same with my Suburban. But I am swapping the motor and putting a fuel cell in. Good luck with the truck!
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
ha thanks, i actually haven't seen the truck in person.
it's in CA, I'm in TX. that's the pic the guy sent me. -so, what would be the absolute worst case? i have about $2000 to put into it after the purchase. as of right now i don't have many details other than what i've already mentioned. -what do i need to find out before a purchase? ps: i know these questions are incredibly naive, but hey that's where i'm at ![]() appreciate your responses Last edited by chimney chop; 04-25-2011 at 03:07 PM. |
I have car A.D.D.
Based on the calculations I did for getting my Suburban road worthy including putting seats in, wheels & tires, dropping my motor and tranny in, and the fuel system...$2,000 should leave you plenty for getting it on the road.
Who Me?
Is this the truck your looking to ship?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Where in CA is it , theres alot of guys here that may help out if close enough?
![]() Join Date: Jan 2011
I would have someone you trust go take a look. Couple of quick checks can tell a lot. Will it turn over with a good battery in it. Will it start if you pour a little gas in the carb, still have brakes and will it roll after you push on the brake pedal. Then just a good look at the entire truck top to bottom.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
With $2000 to play with, I don't think you'll be over budget.
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
#13 |
Senior Enthusiast
More than the cost to get it running, I’d want to make sure it’s something you want to buy. If it’s several states away I’d suggest you need to have someone you trust take a look at it (unless you personally know the seller). The pointers on the following thread can help. Sitting outside for 7 years can allow a lot of rust damage to occur in the usual areas if the vehicle wasn’t protected.
http://www.stovebolt.com/techtips/bu...uide_60_66.htm |
#14 |
i'm a vehicular novice so........
when i go to see it how much should i offer? what large concerns do you see? ps: thanks for all your help guys! ![]() ![]() ![]() ![]() |
#15 |
The first thing to do is to take what ever the previous owner told you about the truck and throw it out the window. All old parked trucks just had a rebuild right before they were parked wink wink. The first thing I see is a newer clear coat paint job that has rust bubles coming through the paint, so it is going to need a paint job at the least and you have to wonder what they covered up. It is going to need that tire fixed to be loaded. If you are in texas why are you buying so far away? I have seen alot of trucks down there that are rust free in texas. You may be better off spending a little more money closer to home and save the shipping for repairs. Just my 2 cents I have seen alot of scams over the net and if you are a novice you are acceptable to them.
#16 |
I just saw the rest of the pics I would be very concerned about it sitting without an air cleaner. I would offer no mor that 1000.00-1500.00 and that was after hearing it run.
#17 |
it has a chevy dash and tailgate with 65 chevy fender emblems,gmc grill and hood.
#18 |
i am confused it has texas plates? if its close to sac i can check it out for you.let me know.
#19 |
oops, yeah this one's in texas.
looking at too many cars got me confused ![]() |
#20 | |
fan of "Butters" Stotch
These trucks rust out in every area of the body, and can happen anywhere in the country. My best advice is to buy something fairly clean & original. Even if it needs work, its still better than something that has been cobbled up by humans over the years. Sorry for my rant, but you'll thank yourself later ![]()
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
#21 |
I'm a bit leery of buying anything that has been sitting that long if I wasn't planning on a rebuild anyway. I bought a 98 Tahoe on ebay a couple years back that was advertised as "in pristine condition". Turns out that it sat out in a field for about a year and a half. A lot of seals and gaskets dried out causing leaks and other problems over the time I owned it. I bought it for $5000 but by the time I sold it I had $17,000 into it. Of that money only $1000 was in upgrades. The rest was fixing its problems. Ebay had a really bad system for grievances back then otherwise I would have returned it and gotten my money back. I realize there is a lot less to go wrong on the older trucks but I would still worry about seals and gaskets being dried out. Just my $.02 worth.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#22 |
That's a Chevy with a GMC grill and headlights. If the title says GMC run away quickly.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
#23 |
#24 |
![]() Join Date: Mar 2011
There is a lot about this truck that screams "RUN AWAY". If you only have $2k to spend on a project then this one is not for you. There are a few aftermarket items added and you can see the truck has been abused. Note the ball on the rear bumper, it's bent down. Why is the rear tire bead completely off? You need to inspect the cab floor....under the carpet. You may spend $2000 to get it to run half decent but you'll always be spending $2000 here and $2000 there.
http://67-72chevytrucks.com/vboard/s...d.php?t=456437 |
#25 |
![]() Join Date: Sep 2006
So once again. Where in Ca is this truck? One of us out here could go look at it for you maybe.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
