TH400 Questions
Will a 2WD TH400 work in a 4X4 with some sort of tail shaft swap??? Or is it a totally different case?
Father has a 1 ton dually with NP205 T-Case, and the tranny is out...Can't seem to find a 4X4 tranny to replace it....therefore looking to see if 2WD would possibly work with some tail shaft changes? I'm a 4 speed guy so any help would be great!!! A............
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
Re: TH400 Questions
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Re: TH400 Questions
Seems I need a 25.00 membership fee to see content on the K5 link....
A........
![]() Join Date: May 2007
Re: TH400 Questions
My th400 for my blazer is the same as short shaft 2wd 400, with the tailshaft housing removed.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Grease Monkey
Re: TH400 Questions
In my experience with chevy trans, you will be able to remove the tail shaft housing and swap out the output shaft.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Re: TH400 Questions
Yup, I believe the case is the same but the mainshaft is different. I have heard that original 4wd cases are heavier castings but cannot personally verify this.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 04-27-2011 at 08:27 PM. |
Re: TH400 Questions
I have a 2wd tranny that has a bolt yoke. This tranny is the same as the early ones that had the 8 track pattern 205. Pre-85 IIRC. 86 and newer requires the short 205 input.
#8 | |
Currently Blazerless
Re: TH400 Questions
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Re: TH400 Questions
Heres a few pics of one of my TH400 205s, you can see how deep the input gear is, this is the one that will bolt right up to a 2 wheel drive TH400
