Old 04-25-2011, 11:41 PM   #1
overtimeracing
overtimeracing's Avatar
1987 Trazer
Hey guys, my son and I are building him an 87 trazer. We are having trouble with the charging system. We are using an older 350 with an internally regulated alternator. We are also using the stock wireing harness from the 87. This had the fuel injection, we just aren't using it. When we remove the alternaton and had it tested, it checked o.k. but when it is on the truck it won't charge. What am I missing?? Thanks... I'll get some pics on here asap. Thx...
overtimeracing is offline   Reply With Quote
Old 04-26-2011, 10:20 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1987 Trazer
Is there no voltage output at all? If so, what is your input voltage?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-26-2011, 10:39 AM   #3
overtimeracing
Re: 1987 Trazer
Input voltage from the batterty? I dont know. 14 volts from a fully charged battery? I can charge it with a battery charger and it will hold a charge, but after running the truck for a while, the battery gets weak. I will get pictures on here today of the wireing. Thx for the response. Kevin
Old 04-26-2011, 10:46 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1987 Trazer
What I am suggesting is its possible you don't have a good input voltage. If the Alt checks good on the bench it should have output in the truck.
Articles-
"Refining Sierra"
Old 04-26-2011, 10:57 AM   #5
overtimeracing
Re: 1987 Trazer
Thats what Im thinking. There is a missing link from the battery, starter, and alternator. Ill show you the pics. Thanks again for the help.
Old 04-26-2011, 11:25 AM   #6
overtimeracing
Re: 1987 Trazer
Old 04-26-2011, 11:27 AM   #7
overtimeracing
Re: 1987 Trazer
http://s729.photobucket.com/albums/w...Marks%20truck/
These are the photo bucket pics. I cant figure out how to post just the pics, but im working on it. Thx...
Old 04-26-2011, 12:01 PM   #8
overtimeracing
Re: 1987 Trazer
Here's the pics... Thx...
Old 04-26-2011, 12:08 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1987 Trazer
The pic below looks to be fusable links. You could have one blown that is causing your issue. Do you have a volt meter or test light? Check the input voltage at the back of the alt and see wht you have. If its not 12-14v then work your way back to the battery.
Articles-
"Refining Sierra"
Old 04-26-2011, 12:16 PM   #10
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: 1987 Trazer
It looks like the brown wire isn't hooked up with all that tape wrapped on it, The brown wire on the alternator must have switched power to give it a reference point to start charging.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-26-2011, 04:41 PM   #11
overtimeracing
Re: 1987 Trazer
This brown wire? Is conneced to ground, currently.
Old 04-26-2011, 05:40 PM   #12
overtimeracing
Re: 1987 Trazer
Just checked the fuseable links (3) all are good.
Old 04-27-2011, 07:28 AM   #13
overtimeracing
Re: 1987 Trazer
Poking around last night with the test light, and discovered there is no voltage at the back of the alternator. The post that the orange wire is attached to shows no voltage. The brown wire (to the right of the orange)will light the test light when the truck is running. Thanks for the help.
Old 04-27-2011, 09:50 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1987 Trazer
Thats what I was thinking. Now you need to find out why?
Articles-
"Refining Sierra"
Old 04-27-2011, 11:02 AM   #15
overtimeracing
Re: 1987 Trazer
N2TRUX...Thanks for the replies...Isn't there supposed to be a large red wire going from the back of the alt to the bat, or starter?
BTW... Thats a good looking Cheyenne you got there.
Old 04-27-2011, 12:21 PM   #16
Restrorob
Restrorob's Avatar
Re: 1987 Trazer
Yes, I missed that in your pics..... There should be a wire the same size as the red one on the alternator post now 10 gage, It should run down to the battery post on the starter. But don't run a wire without adding a 5-6" piece of 14 gage fusible link wire at the starter.
Your local parts house should have a fusible link pigtail with a eyelet on one end to fit the starter post and a butt connector on the other to splice your alternator wire to.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 04-27-2011, 11:18 PM   #17
overtimeracing
Re: 1987 Trazer
Nice... Thanks for the help guys. I think i'm going to run the wire to the firewall, and use the fuseable link already at the starter. Do you guys think that will work??
Old 04-28-2011, 07:01 AM   #18
Restrorob
Restrorob's Avatar
Re: 1987 Trazer
Give it a try, Most can happen is you over power the fusible link and blow it....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
