Roto Reuter thats the name...
![]() Join Date: Feb 2010
What is this column cushion used on?
Can anyone tell me what models use this steering column cushion. I am trying to install an Ididit steering column on my '69 C20 and do not have one of these cushions. I'm wondering if it is required and used on all trucks. I'm just concerned because without this cushion, the column would be clamped on a bump, or nub, at the top of the mount that would push into the column. Anyone who has installed an Ididit column, or has info on this cushion, please chime in. Thanks.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Member #1049
Re: What is this column cushion used on?
Those cushions were used on the C40/C50/C60 trucks, 1/2 thru 1 tons did not have it.. they mounted the column with a clamp and had a "nub" on the pedal support. the steering column had a slot the aligned with the nub
Oh OK, thanks. My concern has been with the mounting of the Ididit column. It doesn't have a matching slot for mating with the nub on the pedal support. It just doesn't seem that clamping it down on that nub is enough to support it. Especially if there is no slot or mating surface. That must be how it goes though.
Part of the problem is that the publisher has removed the part numbers and title blocks from every page of the assembly manual.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
