04-26-2011, 02:23 AM | #1 |
belltech 3120 drop spindles
Ok so I have a set of these 3" drop spindles part number 3120 which is for the 71-72 and searched but dont really have a clear answer yet....So I have an 87 and these are for a 71-72 which is still same stuff basically.... How do I get these to fit my truck???? I already need ball joints and tie rods so I'm prepared to get that stuff just wanna know which stuff to buy for a 71-72 or for 73-87 stuff? clear answer would help from someone thanks...
04-27-2011, 09:45 AM | #2 |
Happy to be here
Re: belltech 3120 drop spindles
Keith? Scoti?
04-27-2011, 10:04 AM | #3 | |
67-72 parts collector,…
1) 71-72 upper ball joints. 2) 71-87 lower ball joints. 3) 71-72 outer tie rod ends. These spindles only work with 1.25" rotors, calipers, and bearings. If your '87 has the light duty 1" rotors,... all of that stuff will have to be changed.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-27-2011 at 10:04 AM. |
04-27-2011, 10:05 AM | #4 |
Just curious,... did you get a smokin deal on these spindles?
I was wondering why you didn't buy the 3100 (HD) or 3200 (LD) Belltech spindles.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-27-2011 at 10:07 AM. |
04-27-2011, 02:52 PM | #5 | |
Josh |
04-27-2011, 03:08 PM | #6 |
A guy with a truck
They will work with the DM, you'll just have to use the 71-72 upper BJs...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-27-2011, 03:48 PM | #7 | |
They will work fine.
04-28-2011, 01:51 AM | #8 |
Cool, thanks guys for clearing it up for me!!!!! Now waiting for parts to come in, so I can tear down and re-do, rebuild. Man the never-ending process continues!!!!!!
12-09-2012, 12:11 AM | #9 |
I just got a hold to some Belltech spindles today and they are stamped 31200. The guy I bought them from says he took them off a 73-87. He says he also thinks they are 2'' drop spindles but when I looked at Belltech's website they dont have any 2" spindles for 73-87, only 3". Also they dont have a parts number for 31200, only 3100 and 3200. Im thinking they are 3'' for a 73-87 but I could be wrong. They fit my 73-87 upper ball joints. Any thought on what I really have??
thanks Slim
Long live SLIM ------------------ At least try to buy American |
12-09-2012, 12:20 AM | #10 |
Belltech still makes the 3120.
http://www.jegs.com/i/Bell-Tech/146/3120/10002/-1 Application is 71-72.
12-09-2012, 12:25 AM | #11 |
Thanks Keith. Ok but my control arms are for a 73-87. Can you see anything in the pic that would say they aren't fitting correctly? Also I assume that 3120 is the same as the 31200 that's stamped on the spindle??
12-09-2012, 12:41 AM | #12 |
I can't be sure by your pics.
Could the upper balljoint be a 71-72 balljoint? 71-72 and 73-87 trucks use the same lower balljoint. The outer tie rod is different. I would bolt them on and use them!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-09-2012 at 01:06 AM. |
12-09-2012, 01:00 AM | #13 |
Heres what I have. It seems to fit so I'll take your advice and go with it.
Thanks once again.
12-09-2012, 02:43 PM | #14 |
Do I have to change my calipers too? I know I have to change the rotors to the heavy duty ones along with the bearings... The auto parts guys are saying its only one caliper # for both LD and HD rotors
12-09-2012, 02:49 PM | #15 | |
Your parts guy is wrong.
12-09-2012, 02:54 PM | #16 | |
12-09-2012, 02:56 PM | #17 |
Found this on the intenet,...
JD7 = Diesel Hydro Brakes JB1 = Manual disc/drum brakes JB3 = Pwr.disc/drum (1" rotor & 11"x2" rear drum) JB6 = Pwr.disc/drum (1.25"rotor & 11"x2.75" drum) JB7 = Vacuum Power Brake disc/drum System J55 = Heavy Duty Power Brake System
12-09-2012, 02:58 PM | #18 | |
That gets you a caliper for 1-1/4" rotors with the non-metric banjo bolt for the brake hose. (7/16-20 thread)
12-09-2012, 03:02 PM | #19 |
Thanks for the fast reply. I'm in the Pep Boys parking lot. Hopefully there's nomore discrepancies
