sway bar
have a few prices on some front sway bars. only question i have is, is 1 3/8 to big? it would cost me an extra $30. if not 1 /1/8 would be the choice.
truck is. 1984 GMC 1/2 ton 2WD |
Re: sway bar
find a 1.25'' bar of a factory 1 ton truck, or maybe a 3/4 ton truck. add some energy suspension bushings and call it a day
![]() it'll be a lot cheaper too
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
Re: sway bar
but 1 3/8 isnt overkill?
the frame i used never had a sway bar on it when i got it. |
Re: sway bar
with sway bars, bigger is better. and if the truck didn't have a factory sway bar you'll need the two brackets that the front sway bar bushings bolt to. they are riveted to the frame from the factory
Re: sway bar
yea, i'll need to take a closer look at the frame, not sure if they were removed, or like you said it didnt come from factory.
thanks for the input =) |
#6 | |
Happy to be here
![]() Join Date: Mar 2000
Re: sway bar
Regardless, you will need the factory hardware including the frame "stands" that the bushing clamps mount to. If your truck is lowered you can run the Early Classic Enterprises short stands. If your truck is really low you can bolt the clamps directly to the frame. The amount of drop you have will determine what method of mounting will work best for your truck.
Re: sway bar
priced sway bars at a local performance shop.
Re: sway bar
you might try this route.........i paid 15 bucks for mine at the junkyard.
" Never look up a dead dogs butt." ![]() |
Re: sway bar
My belltech is 1-3/8". I would say its not overkill at all. It uses the factory mounts on the frame and an endlink setup that mount to the outer holes of the factory lower a arms.
Posted via Mobile Device |
#10 | |
Re: sway bar
rule with sway bars: you can never go too big...... u dont want body roll.....none. with my bar i still have what i consider "excessive roll".... poly bushings should do the truck tho. |
Re: sway bar
good. that's the setup i priced out. ordering it tomorrow. thanks guys
Re: sway bar
The belltech is a great choice if you ever plan on aftermarket A-arms. And because its burly. If you want a better value, the 1 ton setup is the way to go.
#13 |
![]() Join Date: May 2009
Re: sway bar
You'll have to let us know if you notice a difference once you get it put on. I just bought an 1 3/8" front and an 1 1/8" rear this week on craigslist (wasn't looking but couldn't pass it up). I'm in no hurry to get them on, the front is missing two bushings. The 1 3/8" is a big bar!
#14 |
Re: sway bar
Has anyone made their own "stands' for the sway bar to mount to? I'm thinking some 1" square tubing or something? I got the sway bar from parts truck, but the truck it's going in never had one. I didn't realize I needed the stands until after the chassis was sold.
My 68 cougar restomod build:HERE |
#15 |
Re: sway bar
LMC truck sells the stands.
