04-26-2011, 03:01 PM | #1 |
Tailgate weld up - got question????
Wanting to weld up my 69' c-10 tailgate. i have seen a few threads on this just still not clear on how to go about it. Tips and trick welcome- bring'em!!
""Don't Tread on me is how live and i'll take it to my grave"" My restoration video....... http://www.youtube.com/watch?v=tU9fhHcDivs |
04-26-2011, 04:48 PM | #2 |
Re: Tailgate weld up - got question????
I would highly reccomend getting a skin, such as a california combo from Grant customs before you try and weld up the factory gate. It looks like the pic below, and can be ordered HERE
While it can be done with the origional tailgate, the gaps are much larger than you would want, as well as I have seen lots of shaved beds that crack out when done this way. When you install the cali combo, you remove the tailgate and brace the bed with square tubing, so the bedsides do not move and crack the welds. Then you skin the bracing with the cali combo, which is a little oversized so you can trim it down so the gaps are perfect for welding up. It should take very little body filler if done carefully. Here is a pic of an S-10 that was braced for a cali combo skin, so as to keep the bedsides from moving. All he will have to do is weld the skin in next, and he is done. Hope this helps. |
04-26-2011, 05:21 PM | #3 |
what kinda weld up are you talking about? like to where it will never open again? or weld up holes?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
04-27-2011, 11:34 AM | #4 |
The local Derby guys use rectangle flat steel about 6 inches long on top and bottom, 4 pieces and make the gates perminent.
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
