04-26-2011, 05:53 PM | #1 |
Crankshaft!!! Please help
I bought new chrome pulleys for the crankshaft and water pump! However the waterpump pulley seems to be an 1/8 of an inch deeper then the old one so the grooves arent lining up perfectly. I was wondering if it would be a bad idea to put washers between the crankshaft pulley and the harmonic balancer so it would line it up with the water pump pulley, and if that is a bad idea, does anyone have any ideas on how to make them line up the right way!?!?!?
1967 C10 Long Bed, Soon to have a 350 1997 Chevy 2500 454 BB |
04-26-2011, 06:09 PM | #2 |
Has more rust than truck...
Re: Crankshaft!!! Please help
04-27-2011, 08:27 AM | #3 |
Good Info
04-27-2011, 10:46 AM | #4 |
I went to a hardware store and got a large washer, drilled four holes in it and made a homemade spacer. It is a lot better than a stack of washers behind the pulley IMHO, and is a quick/easy fix.
04-27-2011, 12:23 PM | #5 | |
but if you look at the water pump.. the mount for the pulley is pressed on the shaft.. you can move it if needed.. |
04-27-2011, 12:51 PM | #6 |
Between Trucks...
Ready made shims are also available for this, check out Summit Racing.
Beat it to fit, Paint it to match... |
