04-26-2011, 06:30 PM | #1 |
94-96 Impala/Caprice disc brake rearend questions
Does anyone know the length of the Impala/caprice 9C1 disc brake rearends? Diamater of the axle tubes?
Just thinking if its the same or a little narrower It might be cheaper to just swap a complete rearend instead of buying conversion axles and disc brakes for my 1968 housing.
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 04-26-2011 at 06:32 PM. |
04-26-2011, 07:07 PM | #2 |
Re: 94-96 Impala/Caprice disc brake rearend questions
93-96 sedan
1566mm - narrow (9C1 - disc & drum & some other drum applications) 1598mm - wide (Impala SS - disc & B4U - drum) I am looking to run the wide. <edit> Not sure of the axle tubes, but you'll have to do perches anyway.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 04-26-2011 at 07:08 PM. |
04-26-2011, 09:57 PM | #3 | |
It will be welding to a SD super lift wishbone setup, so I need to determin if I need to have SD make me a new set of axle mounts or if the ones I have will work.
Doug Looking for a 67-72 short bed driver..... |
