Old 04-26-2011, 06:46 PM   #1
808humbo1
tailgate lift support bracket thing.....
for a 72 burb....where can i get a pair of these!!!???? i dont know exactly what they are called but they hold up your glass part of your tailgate.......i have to push mines up about 20 - 30 times to disengage it to bring it down..i figure its time for a new set....
thanks in advance!
No Grumbo Be Humbo
808humbo1 is offline   Reply With Quote
Old 04-26-2011, 09:25 PM   #2
vectorit
What?
vectorit's Avatar
Re: tailgate lift support bracket thing.....
Those are salvage yard parts.
You may think about taking them off, then soaking them in a water based de greaser for a while. Then lube them with a fine oil, while working them back and forth to get the dirt and gunk out of the mechanisms.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-26-2011, 09:44 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
heck, just squirting some good spray lube like PB blaster in there may do wonders.
Old 04-28-2011, 01:42 PM   #4
808humbo1
thanks guys! i'll try lube it up again....i think theres a little piece missing/broken.....there's only a lock piece on one side don't know what happened to the other....thanks again for the help!
No Grumbo Be Humbo
Old 04-28-2011, 06:47 PM   #5
DINS 1
DINS 1's Avatar
you could change to gas cylinders like hart_rod did. look at this it is the faq section
http://67-72chevytrucks.com/vboard/s...d.php?t=220511
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 04-29-2011, 06:37 PM   #6
Mikmark
I replaced the brackets with the gas tubes as described in the referenced article. Very easy an quick to do. The brackets on my 72 were so worn that the safety catches were unreliable (and unpredictable!). I used to prop the window open with a broomstick before I would stick my neck under what felt like a guillotine. This was a very nice mod.
1972 C10 Suburban
1959 Austin Healey Sprite
1977 Datsun 280Z
Mikmark is offline   Reply With Quote
