Old 04-26-2011, 08:32 PM   #1
67Slider
67Slider's Avatar
Exhaust Tip Location - Post Pics
My old truck is in need of a new exhaust. The shop says I will probably have to exit just in front of the back tires. I've got a 3/5 drop. Post some pics of your exhaust tips so I can get a better idea of what they look like in front of or behind the back tire. I've also got the Camaro tank installed so it limits the straight back exhaust.
Thanks,
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 04-26-2011, 08:45 PM   #2
suville
suville's Avatar
Re: Exhaust Tip Location - Post Pics
Runnin bags and this is 2.5 inch mandrel exits thru cutouts in bumper
suville is offline   Reply With Quote
Old 04-26-2011, 08:45 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I ran some jeep springs awhile back 4 inch drop or so, and the mufflers hit the axle...
John
1999 Toyota Tacoma 4x4
Old 04-26-2011, 08:47 PM   #4
67Slider
67Slider's Avatar
I've got some glasspacks on there now and they are hitting the trailing arms. That's what is driving the new exhaust.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 04-26-2011, 08:59 PM   #5
lakeroadster
I ran mine on the outside of the frame rails. Long tube Headers, 30" Cherry Bombs, 2-1/2" pipes running to back roll pan. Ended up cutting the exhaust off nearly flush with the roll pan, I didn't want the tips to stick down since everything looks smooth across the back.
Pretty stoked with the way it sounds too, here is a video clip
lakeroadster is offline   Reply With Quote
Old 04-26-2011, 09:02 PM   #6
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Originally Posted by 67Slider View Post
My old truck is in need of a new exhaust. The shop says I will probably have to exit just in front of the back tires. I've got a 3/5 drop. Post some pics of your exhaust tips so I can get a better idea of what they look like in front of or behind the back tire. I've also got he Camaro tank installed so it limits the straight back exhaust.
Thanks,
With that drop you will have no prob. going over the axel and exiting out the rear. Mine is bagged with bolt in C-notch over the axel exiting at both rear corners out of site no tips.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 04-26-2011, 09:17 PM   #7
big_al_71
big_al_71's Avatar
six inch drop and over the axle out the back...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-26-2011, 09:26 PM   #8
67Slider
67Slider's Avatar
Lakeroadster,
Very nice! Sounds great too.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 04-26-2011, 09:32 PM   #9
CG
BlahBlahBlah
Lakeroadster,
Yeah I was thinking the same thing. Ive always gravitated to Flows, but those Cherry Bombs sound really mean!
Old 04-26-2011, 09:33 PM   #10
lakeroadster
Lakeroadster,
Thanks!
I just didn't see the sense in running the exhaust through the control arms, around the shocks, over the axle, around the track arm and around the rear gas tank. Plenty of space between the frame and the tires... seemed the best way to run the exhaust and still allow maintenance access to suspension components. And less bends = less flow restriction
But then again I always do things different.
Old 04-26-2011, 10:20 PM   #11
gonnuts
gonnuts's Avatar
Just had mine done, I only have 3" drop though.
http://67-72chevytrucks.com/vboard/a...1&d=1303870607
gonnuts is offline   Reply With Quote
Old 04-26-2011, 10:32 PM   #12
AusTx68
AusTx68's Avatar
So mine seemed a bit unorthodox when it was suggested by the guy at Meineke Muffler but I went with it. Due to my 6" rear drop and aluminum tank they routed the 2 1/2" pipe under the differential and added Pypes exhaust tips. Is this right? Hell if I know but it works so far and does not hit the differential. I'm still not sure of the look but it mellowed the tone of the super 40s nicely.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 04-26-2011, 10:48 PM   #13
Hart_Rod
Hart_Rod's Avatar
My 68s exhaust...
Hart_Rod is offline   Reply With Quote
Old 04-27-2011, 08:55 AM   #14
68Stepbed
68Stepbed's Avatar
3.5/5 drop here. Mine has 2.5" pipes and goes over the axle. My exhaust hits, but that's only because the dodo head that did my exhaust didn't know what he was doing. I need to have it redone and I'll get to it one of these days, but for now, it's not a big issue. It can be done. You just need to get a good exhaust shop with an experinced bender to do the work.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-27-2011, 12:50 PM   #15
jhwkns
Registered Cruiser
jhwkns's Avatar
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 04-27-2011, 01:02 PM   #16
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Rob, sounds good. Sounds similar to mine, only I don't have a blower. What cam are you running? I like the exit on yours, too.
Do you have a sound clip of the dumps? Or, was that it?
Member Nr. 2770
Old 04-27-2011, 01:57 PM   #17
Hart_Rod
Hart_Rod's Avatar
The beginning was with the dumps closed, the middle the dumps were open, and the I closed them again at the end. I'll do a better video after I get it dyno tuned.....
Cam information:
Competition cam - XR276HR-12
----Operating Range:1800-5800
----Duration Advertised:276° Intake/281° Exhaust
----Duration @ .050'':224° Intake/230° Exhaust
----Valve Lift:.503° Intake/.510° Exhaust
----Lobe Separation Angle:112°
The motor is only 9:1. I have more information on it in my 68 S/C thread.
Old 04-27-2011, 05:32 PM   #18
jim-bob
Originally Posted by jhwkns View Post
....hey john, you happened to have a pic of a direct shot of the back of your truck..I may go that route..thanks..jimbob
jim-bob is offline   Reply With Quote
Old 04-27-2011, 10:33 PM   #19
jhwkns
Registered Cruiser
jhwkns's Avatar
Sorry, but my truck's apart for paint right now. The tailpipes line up with the notches in the sport bumper. Look at big_al_71's truck in post #7 of this thread for a good example.
The bed's off so here's a look at how it's routed. It's got Long tube headers with 2.5" pipe. The mufflers are the biggest quietest OEM type that would fit under the cab. It's really quiet. All you hear is the intake which is pretty loud at WOT. The sound of it reminds me of a cop car. I like the quiet pipes. It's nice to not have to shout at your passenger on the highway.
I shopped prices, and they were all over the map. I was quoted as high as $475, but I ended up paying $250, with me supplying new collectors. The guy was a wizard with his tubing bender. I'm not sure how many bends are there, but he did it with one piece of tube from the mufflers back. He and his helper had it done in just a little over an hour.
Old 04-28-2011, 05:56 AM   #20
67C10BUB
67C10BUB's Avatar
Here's mine.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 04-28-2011, 07:54 AM   #21
jim-bob
I completely over looked big-al's..yeah, I like that position.. thanks for the reply!
