04-26-2011, 09:37 PM | #1 |
Young gun
tire height?
How tall is a 60 series tire on a 15" wheel? Thanks
67 SWB Custom "JANE" http://67-72chevytrucks.com/vboard/s...d.php?t=554024 Northwest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ Cameron sparks |
04-26-2011, 09:41 PM | #2 |
Re: tire height?
depends on how high the tire is...the 50-60-70 tires are base on percent of how wide.
go to http://www.1010tires.com/tiresizecalculator.asp its a tire calculator I use alot.
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
04-27-2011, 10:30 AM | #3 | |
Young gun
Re: tire height?
04-27-2011, 10:47 AM | #4 |
Re: tire height?
Sorry but to answer that you really need to decide you want a 50-60-70-75 tire?
04-27-2011, 02:06 PM | #5 |
Re: tire height?
I'm runnin 275/60/15
04-27-2011, 02:15 PM | #6 |
Young gun
Re: tire height?
I was thinkin somewhat between. 255 -275/60/15
04-28-2011, 12:41 AM | #7 |
Fabricate till you "puke"
Re: tire height?
255/70/15(29"tall)....she runs cool in OD on the hyway(105 @ 3150 on the tach)....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
