Has anyone compared all the aftermarket fenders??
I think there are 4 manufacturers unless they all are reboxers...I found a place here in Detroit that advertizes detroit made ,but their part numbers are same as cross canada/taiwan/sherman .. I know there a few and I hope someone on here has compared them ..
Re: Has anyone compared all the aftermarket fenders??
all I`ve heard from the few on here is they have to massage to fit....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
My dad didnt have very good luck with them, they didnt come with the rear support, the bolt holes were way off ( some were 1" off) and the nose of the fender where the front grill surround connects wasnt lined up properly, he sent them back and got some original fenders and had them cleaned up and repaired, those fit perfectly. I dont know what brand they were though
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
What about fenders purchased from LMC? Anyone used their's?
Here is what I would advise. BEFORE you touch a new fender, find out the cost of repairing yours, whether you do it or have it done.
Before you do anything to a new fender, verify it will fit your project completely, then have it painted. remember, even new fenders will need some body work. I think Goldmark's sheet metal is the better option, I could be wrong but I think they are the better. Call your selected vendor and ask who makes the sheet metal they are selling, they should tell you, if not, dont buy from them.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 04-28-2011 at 12:40 PM. |
#6 | |
![]() Quote:
Cross canada , Goodmark, Key parts ,and there are others .. wish a few of the dealers wou chime in on this ... Last edited by awbrown; 04-28-2011 at 01:54 PM. |
Goodmark, nothing else I've tried has ever been better than "close enough".
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Yes your right, Goodmark, my fingers dont always type what my mind say.
bump, any other input on this? I found this site: http://www.classicdiscountparts.com that sells Auto Metal Driect, Dynacorn and Goodmark fenders for waay cheaper than any one else I've seen.. Thinking about getting a fender too, but like everyone else, don't know which to choose.
My build thread: '66 Chevy |
Hey Chill , order one of each and tell us what you think !! LOL You could become the expert on fenders!!
I bought fenders from Tuckers that are Triplus brand. They are crap. I couldn't use them on my good truck. They looked good from the side, but they are 1/4" shorter than stock, don't line up in the front, there are triangle holes in the front corners because they fold the metal over wrong in the stamping, the bolt holes will not line up and have to nearly come out of the lip on top of the inner fender to line up. Add to that that they are made out of bad steel in comparison to the originals. They may measure the same gauge, but it dents like a pop can. About Goodmark! I bought inner fenders from them and they are selling Triplus. They are soo bad that the body shop didn't want to use them. The front mounts would have to be cut off and repositioned. The hood hinge mounting points are in the wrong place. The part that mounts to the cab is welded in wrong and causes it to be crooked to one side. These could have been used if we cut off and rewelded all of those mounting points and maybe redo all of the fender mounting holes. It was cheaper to find originals and fix them. I have just decided not to buy any aftermarket again except for MAR-K. My front bed panel and side trim from them were better than factory. Awsome fit, heavy duty, looked great. The body shop bought a bed wood kit from them and it was great as well.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
