Old 04-26-2011, 11:59 PM   #1
Davedr
Davedr's Avatar
Spindles
If I replace the original spindles with 2.5 drop spindles, Will I have to go with different top & bottom ball joints? I bought some new stock ball joints from the auto parts store and the pin holes won't line up with the nut. Here is a pic of the bottom ball joint. Not a very good pic.Thanks in advance... Dave
Davedr is offline   Reply With Quote
Old 04-27-2011, 10:10 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Spindles
What year drop spindle?
What year ball joints did you buy?
The aftermarket spindle companies (Belltech, McGaughy's, CPP, POL, Western, etc) make year specific spindles so you don't have to change anything.
They break down as follows:
60-62
63-70
71-72
73-87
Keith
Convert to disc brakes.
Old 04-27-2011, 12:59 PM   #3
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: Spindles
Not to hijack the thread but is there a breakdown on a arms? I read a lot about using the 73-87 suspension including crossmember. I assume 72-73 is a breaking point but what a arms fit what spindles?
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
Last edited by propanemudtruck; 04-27-2011 at 12:59 PM. Reason: I caint spell sometimes
propanemudtruck is offline   Reply With Quote
Old 04-27-2011, 01:29 PM   #4
lolife99
lolife99's Avatar
Re: Spindles
All 1/2 ton and 3/4 ton upper arms are the same.
Break down:
63-72
73-87
All 1/2 lowers are the same.
Breakdown:
63-72
73-87
* 3/4 ton lowers have a larger ball joint hole.
* 63-72 have steel cross shaft bushings.
* 73-87 have rubber cross shaft bushings.
* All arms can be swapped between the (63-72) crossmembers and the (73-87) crossmembers.
* 73-87 lower a-arms use a slightly bigger u-bolt to mount them.
(easily fixed with a drill)
Keith
Old 04-28-2011, 09:15 PM   #5
iceship
Re: Spindles
What other years. Will fit a 87 silverado ... seen other drop spindels for sell just don't know if they will fit...
iceship is offline   Reply With Quote
Old 04-28-2011, 09:26 PM   #6
lolife99
lolife99's Avatar
Re: Spindles
73-87 spindles will fit your 87.
Keith
