Old 04-27-2011, 12:22 PM   #1
argonaut
argonaut's Avatar
Deciding on a 4-speed Transmission
I'm trying to decide which transmission will go back into my 66 when I re-install the drivetrain. I have two sm420's available and an sm465. The motor is a bbc 402 and I'll be using a divorced T221 rockwell transfer case.
Any reason why I should use one vs the other?
The truck will be mainly used on the street with some off road use on weekends, but no crazy wheeling over boulders and up shear cliff faces...
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 04-27-2011, 01:13 PM   #2
Redcap
Re: Deciding on a 4-speed Transmission
SM420 7.05 3.57 1.70 1.0
SM465 6.55 3.58 1.57 1.0
They are both tough transmissions, though I think it is easier to find parts for the SM465.
Redcap is offline   Reply With Quote
Old 04-28-2011, 10:18 PM   #3
DieselEater
DieselEater's Avatar
You won't use 1st gear on either anyway so you might as well have the lower gear of the SM420 for occasional specialty use...
If you've ever run an SM465 up a steep grade in Colorado with a load of aggregate and a sub-500HP engine, then you know that the jump from 3rd to 4th is like too far...You over rev in third, and almost die out in 4th.
The point is, you get a benefit in two areas with the 420 which makes this decision a no brainer...
BTW...I'd like to get my hands on your other 420...
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
