Old 04-27-2011, 05:39 PM   #1
manimal
manimal's Avatar
quadrajet gurus.....need help
Are the power pistons from 4MV's interchangeable with other 4MV's? My carb # is 7043507 if needed. Thank You in advance.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-27-2011, 08:03 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: quadrajet gurus.....need help
They should be the same for all MV series carbs, The difference is the piston spring tension and of course metering rod size per the application.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-27-2011, 08:58 PM   #3
bmchevy1979
bmchevy1979's Avatar
I would think so because I changed the power valve in my 4MV to one from a M4MC without any issues
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 04-27-2011, 10:13 PM   #4
rare86
Extended cab fanatic
rare86's Avatar
i have swapped them as well with no issues
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
Old 04-27-2011, 10:53 PM   #5
manimal
manimal's Avatar
Thank you guys.
-Lance
Old 04-28-2011, 12:41 PM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
http://www.florida4x4.com/tech/quadrajet/
Malo83 is offline   Reply With Quote
