Old 04-27-2011, 07:27 PM   #1
CEE1NG_RED
...breathers and pcv breathers.
Where did you get your breather cap and pcv breather cap from? Also, what type of rubber grommet did you use, open or one w/ the slant airvent cut one?? Lastly, is it bad or harmful to the engine if I just simply run two breather caps and just keep the PCV valve plugged on my 1405 Edelbrock carburetor? I'm trying to get my '67 running.
FYI: It has a '78 350 shortblock motor.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 04-27-2011, 08:30 PM   #2
Dark Knight
Dark Knight's Avatar
Re: ...breathers and pcv breathers.
You need to have a PCV valve on that engine. If you don't, the crankcase pressure can cause all sorts of problems. Just use a PCV valve in one hole, and a breather in the other. A standard round grommet should work just fine. Most parts stores usually have this stuff in stock in the accessory section.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
