04-27-2011, 09:19 PM | #1 |
Power steering pump/ pulley ???
What did the double groove power steering pump pulleys come on from the factory? Wasnt sure if it was a big block thing or maybe small block w/ AC? Does anyone know if the pumps are the same? Looking to swap my single pulley for a double. Thanks
04-28-2011, 12:40 AM | #2 |
VA72C10
Re: Power steering pump/ pulley ???
not 100% sure but 95% that it was any truck with A/C...
Looking for a 67-72 swb or blazer project in or around VA. |
04-30-2011, 07:41 PM | #3 |
Thanks VA72c10 I will check around.
05-01-2011, 01:53 AM | #4 |
i got mine of a 67 to 72 gm a body but any ps pulley off any pre 87 truck or car (may be even newer if the pump looks the same it will work) will work for mine i am grafting in hydro boost so i will be using a pump from a 85ish cucv blazer on the a body bracket and putting the smaller a body double pully back on
05-01-2011, 08:54 AM | #5 |
Knuckle Buster, Instructor
There are 2 pulley styles, (Press on and Keyway with a nut) Just pick which one you need to match the pulley or pump you want to run.
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
05-01-2011, 09:24 AM | #6 |
the four 71-72 trucks i had with AC had single groove PS pulleys on the 350's pretty sure they were all factory stock setups
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-01-2011 at 09:25 AM. |
05-01-2011, 01:45 PM | #7 |
Spanked once
I just changed the brackets on my 71 from Bills hotrods that were high mount 600 series to his 1100 series. While ordering the wide mounts he explained the difference was in a short or long water pump....short 1 groove... long 2 groove.
The ole 350 budget build. |
