Old 04-27-2011, 09:46 PM   #1
rhodog77
rhodog77's Avatar
Thermostat Questions
Hey Guys,
I need to pick up a thermostat switch for my electric fan. Does anyone have any recommendations of which style, probe or screw in, adjustable or non adjustable. Im looking at one from hayden that has a probe that goes into the radiator hose or down into the radiator itself. Sounds like some people even run it thru the radiator fins. Its adjustable and in my price range.....cheap!!! I have read a lot of positive reviews about this product.
http://www.summitracing.com/parts/HDA-3653/?rtype=10
I have 2 locations on the intake to use if I go with the thread in type
http://www.summitracing.com/parts/PRF-30111/?rtype=10
If anyone has experience with these setups I would really appreicate some info before I pick one up.
thanks
brian
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 04-27-2011, 09:56 PM   #2
skip99
skip99's Avatar
Re: Thermostat Questions
I used the thread in...non adjustable switch
works fine
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 04-27-2011, 10:22 PM   #3
kaycee
kaycee's Avatar
I use the same as skip no problem from it yet
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-27-2011, 10:45 PM   #4
solidaxel
solidaxel's Avatar
works fine
Screw into the block with at least 10* higher than the thermostat opening.
That switch provides a ground to your relay which will complete the circuit to the + wire on the fan
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-28-2011, 04:43 AM   #5
skip99
skip99's Avatar
yep, good clarification solid, I think mine is a 190 on 170 off, or 195 on 170 off but the thermostat is a 180. that way the fan only comes on when needed, usually not moving at idle..
Tami's 51 build
Old 04-28-2011, 06:45 PM   #6
BlueJeep
BlueJeep's Avatar
I've been running the SPAL screw into the head style for 10 years with no issues (non adjustable). It's simple and it works....and I don't feel this is an area that needs to be over-complicated with adjustability.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-28-2011, 06:53 PM   #7
Indian113
Indian113's Avatar
I have the kind that goes into the fins on radiator in my 64. It's adjusted to turn the fan on as soon as the thermostat opens up. I have used it for 2 years and in some really hot weather including driving in parades and traffic at GG's in Des Moines still working good
Indian113 is offline   Reply With Quote
Old 04-28-2011, 07:32 PM   #8
rhodog77
rhodog77's Avatar
awesome info!!! Great point about using a sensor that is slightly above the thermostat setting.
I called around a few junkyards, they wanted between 25 and 40 bucks. At that price, Im going to just pick up a new one. Here is the fan that Im looking at. I am pretty tight on space so I like the fact that it is reversible.
http://cgi.ebay.com/ebaymotors/SUPER...Q5fAccessories
with this relay,circuit breaker kit
http://cgi.ebay.com/ebaymotors/FAN-T...Q5fAccessories
any thoughts??
1970 P10 Stepvan
Old 04-28-2011, 11:09 PM   #9
solidaxel
solidaxel's Avatar
You nailed it Blue Jeep,,,, K I S S
LS 3 4L70E
Old 04-29-2011, 10:52 AM   #10
MrDude_1
the experiences ive had and witnessed others had is not to great with them. they dont really last. Ive seen everything from the "box" suddenty not working, to it not working "when wet" to the probe falling out of the fins, to it breaking..also, the temp that it comes on changes.
overall, i think of them as unreliable, plus they're a large, clunky thing underhood.
the best way in my opinion is what was mentioned above.
use a factory replacement fan switch sensor... I have owned 5 third generation camaros, and because of that, that is the sensor-switch I use.. just because im fimilar with it... but it works like they said.
the sensor screws into the block or the head.
when it reaches its preset temp, it grounds its single wire to the block/head that its screwed into.
that single wire will ground your fan relay, and kick the fan on.
the fan relay should have ignition power to its switch coil, and fused constant power to the fans power side... that way the fan only comes on when the key is on, but it doesnt draw power through the ignition switch.
if you need a diagram i'll take the time to make one for you....
MrDude_1 is offline   Reply With Quote
Old 04-29-2011, 05:32 PM   #11
rhodog77
rhodog77's Avatar
Mr Dude,
thanks for sharing the info. I think I have made my mind up. Im going with the tread in sensor. I will probably order it this weekend. Thanks for offering up a wiring diagram. I might hit you up if the instructions are confusing.
thanks everyone for you input. I will post some pix once I get it in
brian
1970 P10 Stepvan
Old 04-30-2011, 10:44 AM   #12
BlueJeep
BlueJeep's Avatar
Mr Dude,
brian
As for the wiring, it's a basic relay with power in, power out to accessory (fan), ignition hot, and the sensor provides the ground for the relay.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 05-01-2011, 04:16 AM   #13
solidaxel
solidaxel's Avatar
[QUOTE=rhodog77;4651804]awesome info!!! Great point about using a sensor that is slightly above the thermostat setting.
any thoughts??[/QUOTE
I just looked at those ebay items ant that relay kit is cheaper than the last 200* sensor I bought. but it!!!
LS 3 4L70E
Old 05-01-2011, 08:58 AM   #14
rhodog77
rhodog77's Avatar
I ordered it on friday. The info on the ebay page was a good read as well. I happened to run into a few rodder buddies of mine at a cruise in last night. a couple of them have bought this exact fan from skip white perfromance. They love them and havent had any issues. You cant beat the price. Hopefully Im as satisfied as they are. This is pretty much tht last thing I need to take care for before getting my project on the road. I cant freakin wait!!!!
1970 P10 Stepvan
