Old 04-27-2011, 09:51 PM   #1
dsy1
Brake pedal squeak
My '71 with power brakes has a bad squeak whenever I step on the brakes. I've tried spray lubricant on the shaft and pivot points under the dash, but I haven't disassembled anything. Any tips? Are there bushings that wear out that I need to replace?
dsy1 is offline   Reply With Quote
Old 04-28-2011, 12:40 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Brake pedal squeak
maybe the brake switch itself squeaking or the rubber pedal squeaking against the metal?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-11-2012, 04:54 AM   #3
wrwelton
wrwelton's Avatar
Did you ever figure out why the pedal was squeaking? mine is doing the same, but squeaks all the time unless i lift pedal with my foot.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline   Reply With Quote
Old 08-13-2012, 11:28 AM   #4
k2rm
k2rm's Avatar
Mine did this. Found out it was a loose booster. Tightened the 4 nuts down on the firewall and the squeak went away.
k2rm is offline   Reply With Quote
